makeMKV 1.8.1 failed to initialize
wandazorro
#1 Post by wandazorro » Fri Apr 26, 2013 6:08 am
gentoo-linux
I installed makeMKV version 1.8.1 both source and binary.
At start both fail with an "Application failed to initialize" error message,
but no further details.
Is there a way to find out what's wrong?
(V. 1.8.0 worked but after reinstall fails too..)
Thanks for any help..
Re: makeMKV 1.8.1 failed to initialize
#2 Post by mike admin » Fri Apr 26, 2013 8:06 am
what happens if you run console version, makemkvcon?
wandazorro
#3 Post by wandazorro » Fri Apr 26, 2013 3:01 pm
makemkvcon info dev:/dev/sr0
Failed to initialize
the mkv command brings the same error too,
whereas "makemkvcon" alone brings it's help page
#4 Post by mike admin » Sat Apr 27, 2013 6:40 am
makemkvcon --debug -r info disc:0
Any debug messages?
wandazorro
#5 Post by wandazorro » Mon Apr 29, 2013 5:41 am
sadly no..
wandazorro
#6 Post by wandazorro » Mon Apr 29, 2013 6:10 am
It's working!
I removed everything "manually", and rebuild/reinstalled the
1.8.1 source version.
I will test if the gentoo "makemkv" package, installed
via "emerge", is working.. (just for interest) and if no,
complain at the gentoo team..
Thank You for your help!
