Glee, Season 1, Disc 2
8bitheart
#1 Post by 8bitheart » Sat Apr 20, 2013 5:41 pm
I've ripped the entire first season from a brand new blu-ray ...
except for disc 2. I insert the second disc, it recognises it, it's starts to do it's thang.. and then nothing.
MakeMKV v1.8.0 darwin(x86-release) started
Optical drive "BD-ROM TSSTcorp DVDWBD SH-B123L SB02" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Failed to get BD disc information, reporting double-layer BD-ROM to BD+ code
Loaded 252 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
BD+ code processed, got 1 FUT(s) for 6 clip(s)
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
File 00802.mpls was added as title #2
File 00803.mpls was added as title #3
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '0'
Title #00804.mpls was skipped
File 00805.mpls was added as title #4
Title #00001.mpls has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00801.mpls and was skipped
Title 00852.mpls is equal to title 00802.mpls and was skipped
Title 00853.mpls is equal to title 00803.mpls and was skipped
Title #00854.mpls was skipped
Title 00855.mpls is equal to title 00805.mpls and was skipped
Title 00451.mpls is equal to title 00800.mpls and was skipped
Title 00453.mpls is equal to title 00800.mpls and was skipped
Title 00454.mpls is equal to title 00800.mpls and was skipped
Title 00455.mpls is equal to title 00801.mpls and was skipped
Title 00457.mpls is equal to title 00801.mpls and was skipped
Title 00458.mpls is equal to title 00801.mpls and was skipped
Title 00459.mpls is equal to title 00801.mpls and was skipped
Title 00460.mpls is equal to title 00801.mpls and was skipped
Title 00461.mpls is equal to title 00802.mpls and was skipped
Title 00462.mpls is equal to title 00802.mpls and was skipped
Title 00463.mpls is equal to title 00802.mpls and was skipped
Title 00464.mpls is equal to title 00802.mpls and was skipped
Title 00465.mpls is equal to title 00802.mpls and was skipped
Title 00466.mpls is equal to title 00803.mpls and was skipped
Title 00467.mpls is equal to title 00803.mpls and was skipped
Title 00468.mpls is equal to title 00803.mpls and was skipped
it just stops here... the time goes up and up and up but nothing happens. All other discs loaded up perfectly fine and ripped ok, but I don't know what's going on with this disc? It's not scratched, and the drive im ripping with is brand new and has ripped 60 other discs without a problem.
Help me!!
crowfax
Re: Glee, Season 1, Disc 2
#2 Post by crowfax » Sun Apr 21, 2013 9:50 pm
The posix error means it can't read the disc. Swap the disc for a new one.
