Makemkv not working after only 2 weeks
wunderlong88
Post by wunderlong88 »
I installed Makemkv on 4-4-2013 and now it wants me to "download" or "register". I thought it had a 30 day free trial period.
Also, I don't know what it means by download. I tried to uninstall and redownload but it still has the message.
The program will no longer work until I do one of these.
Lovely Rita
Re: Makemkv not working after only 2 weeks
Post by Lovely Rita »
Registered User :wink:
Buy MakeMKV
wunderlong88
I thought it was supposed to work for free for dvds. So I still need a registration key to make it work for standard dvd?
Lovely Rita
While in 'beta" the program is time limited, the "free" key is good for 60 days.
Buy MakeMKV
cruelas01
Post by cruelas01 »
If it is only a temporary free, where/how do you buy?
Lovely Rita
Buy MakeMKV
NodNarb012
Post by NodNarb012 »
wunderlong88 wrote:I thought it was supposed to work for free for dvds. So I still need a registration key to make it work for standard dvd?
The DVD portion is supposed to be free for life. Are you running the latest version, 1.8.0? If not, that's probably what it means when I says it wants you to download.
The Blu-ray portion is time-limited when using the free registration key that gets posted to the forum by the developer regularly. He provides a new free key once the prior one has expired; this practice will end once the program leaves beta.
If you want to buy a permanent registration key, you can do so here
Smithcraft
Post by Smithcraft »
Either through the application itself, or from the link in my sig.
SC
