I love this software however I downloaded it 3 times the last 2 because it said it was out of date, after the second install I removed the software from my system and downloaded and installed again but still getting error of the version being to old. Any fixes?
Thanks.
New version downloaded twice but no worky
Re: New version downloaded twice but no worky
Yeah, same thing just happened to me.
First tried uninstall from control panel programs (Win7), then from MakeMKV uninst; same thing both times.
I know this happened before and there was a simple fix, but cant for the life of me remember what it was.
MakeMKV BETA popup
This application version is too old. Please download the latest version at http://www.makemkv.com or enter a registration key to continue using the current version.
OK &Register
MakeMKV BETA popup
OK &Register
- Contact:
The new version will be released very shortly. Meanwhile please use http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
paranutaus
thank you for the key
Cheers and thanks!
