MakeMKV v1.8 on CentOS 6.4 linux - compile errors
ngc4013
#1 Post by ngc4013 » Thu Apr 18, 2013 12:47 am
All suggested libraries are installed. When trying to compile OSS it results in the following output:
mkdir -p out
gcc -Os -D_GNU_SOURCE -D_linux_ -D_REENTRANT -shared -Wl,-z,defs -oout/libmakemkv.so.1.full -Ilibebml/inc -DEBML_NO_READ -DEBML_STRICT_API -Ilibmatroska/inc \
-Ilibmakemkv/inc -Isstring/inc -Imakemkvgui/inc -Ilibabi/inc -Ilibffcodec/inc \
libebml/src/EbmlBinary.cpp libebml/src/EbmlContexts.cpp libebml/src/EbmlCrc32.cpp libebml/src/EbmlDate.cpp libebml/src/EbmlDummy.cpp libebml/src/EbmlElement.cpp libebml/src/EbmlFloat.cpp libebml/src/EbmlHead.cpp libebml/src/EbmlMaster.cpp libebml/src/EbmlSInteger.cpp libebml/src/EbmlString.cpp libebml/src/EbmlSubHead.cpp libebml/src/EbmlUInteger.cpp libebml/src/EbmlUnicodeString.cpp libebml/src/EbmlVersion.cpp libebml/src/EbmlVoid.cpp libebml/src/IOCallback.cpp libebml/src/MemIOCallback.cpp libmatroska/src/FileKax.cpp libmatroska/src/KaxAttached.cpp libmatroska/src/KaxAttachments.cpp libmatroska/src/KaxBlock.cpp libmatroska/src/KaxBlockData.cpp libmatroska/src/KaxChapters.cpp libmatroska/src/KaxCluster.cpp libmatroska/src/KaxClusterData.cpp libmatroska/src/KaxContentEncoding.cpp libmatroska/src/KaxContexts.cpp libmatroska/src/KaxCues.cpp libmatroska/src/KaxCuesData.cpp libmatroska/src/KaxInfo.cpp libmatroska/src/KaxInfoData.cpp libmatroska/src/KaxSeekHead.cpp libmatroska/src/KaxSegment.cpp libmatroska/src/KaxTag.cpp libmatroska/src/KaxTags.cpp libmatroska/src/KaxTrackAudio.cpp libmatroska/src/KaxTrackEntryData.cpp libmatroska/src/KaxTracks.cpp libmatroska/src/KaxTrackVideo.cpp libmatroska/src/KaxVersion.cpp libmakemkv/src/ebmlwrite.cpp libmakemkv/src/libmkv.cpp libmakemkv/src/version.cpp libmakemkv/src/world.cpp sstring/src/sstring.cpp \
libabi/src/ossl_aes.c libabi/src/ossl_sha.c libabi/src/ossl_ec.c libabi/src/zlib.c libabi/src/xpat.c libabi/pssl/ec_key.c libabi/pssl/ec_lib.c libabi/pssl/ec_cvt.c libabi/pssl/ec_mult.c libabi/pssl/ecp_mont.c libabi/pssl/ecp_smpl.c libabi/pssl/ecs_ossl.c libabi/pssl/ecs_sign.c libabi/pssl/ecs_vrf.c libabi/src/httplinux.cpp makemkvgui/src/api_linux.cpp libabi/src/sys_linux.c makemkvgui/src/spawn_posix.cpp libffcodec/src/ffcodec.c libffcodec/src/crc.c libffcodec/src/mlp.c libffcodec/src/mlp_parser.c libffcodec/src/mpegaudiodata.c libffcodec/src/mpegaudiodecheader.c libffcodec/src/aviobuf.c libffcodec/src/ffmdec.c libffcodec/src/ffmenc.c \
-DHAVE_BUILDINFO_H -Itmp \
-fPIC -Xlinker -dy -Xlinker --version-script=libmakemkv/src/libmakemkv.vers \
-Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat
In file included from libmakemkv/src/world.cpp:35:
libabi/inc/lgpl/expatabi.h:24:19: error: expat.h: No such file or directory
libabi/inc/lgpl/expatabi.h:30: error: ‘XML_Parser’ does not name a type
libabi/inc/lgpl/expatabi.h:31: error: variable or field ‘XPAT_ParserFree’ declared void
libabi/inc/lgpl/expatabi.h:31: error: ‘XML_Parser’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:32: error: variable or field ‘XPAT_SetUserData’ declared void
libabi/inc/lgpl/expatabi.h:32: error: ‘XML_Parser’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:32: error: expected primary-expression before ‘void’
libabi/inc/lgpl/expatabi.h:33: error: variable or field ‘XPAT_SetElementHandler’ declared void
libabi/inc/lgpl/expatabi.h:33: error: ‘XML_Parser’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:33: error: ‘XML_StartElementHandler’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:33: error: ‘XML_EndElementHandler’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:34: error: variable or field ‘XPAT_SetStartElementHandler’ declared void
libabi/inc/lgpl/expatabi.h:34: error: ‘XML_Parser’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:34: error: ‘XML_StartElementHandler’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:35: error: variable or field ‘XPAT_SetEndElementHandler’ declared void
libabi/inc/lgpl/expatabi.h:35: error: ‘XML_Parser’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:35: error: ‘XML_EndElementHandler’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:36: error: variable or field ‘XPAT_SetCharacterDataHandler’ declared void
libabi/inc/lgpl/expatabi.h:36: error: ‘XML_Parser’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:36: error: ‘XML_CharacterDataHandler’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:37: error: variable or field ‘XPAT_SetDefaultHandler’ declared void
libabi/inc/lgpl/expatabi.h:37: error: ‘XML_Parser’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:37: error: ‘XML_DefaultHandler’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:38: error: variable or field ‘XPAT_SetDefaultHandlerExpand’ declared void
libabi/inc/lgpl/expatabi.h:38: error: ‘XML_Parser’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:38: error: ‘XML_DefaultHandler’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:39: error: use of enum ‘XML_Status’ without previous declaration
libabi/inc/lgpl/expatabi.h:39: error: invalid type in declaration before ‘(’ token
libabi/inc/lgpl/expatabi.h:39: error: ‘XML_Parser’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:39: error: expected primary-expression before ‘const’
libabi/inc/lgpl/expatabi.h:39: error: expected primary-expression before ‘int’
libabi/inc/lgpl/expatabi.h:39: error: initializer expression list treated as compound expression
libabi/inc/lgpl/expatabi.h:41: error: use of enum ‘XML_Error’ without previous declaration
libabi/inc/lgpl/expatabi.h:41: error: invalid type in declaration before ‘(’ token
libabi/inc/lgpl/expatabi.h:41: error: ‘XML_Parser’ was not declared in this scope
libabi/inc/lgpl/expatabi.h:42: error: ‘XML_Size’ does not name a type
libabi/inc/lgpl/expatabi.h:43: error: ‘XML_Size’ does not name a type
libabi/inc/lgpl/expatabi.h:44: error: ‘XML_Index’ does not name a type
libabi/inc/lgpl/expatabi.h:46: error: expected initializer before ‘*’ token
libabi/inc/lgpl/expatabi.h:47: error: expected initializer before ‘*’ token
libmakemkv/src/world.cpp: In function ‘bool set_world(IWorld*, int)’:
libmakemkv/src/world.cpp:122: error: ‘XPAT_GetCurrentLineNumber’ was not declared in this scope
libabi/src/xpat.c:21:19: error: expat.h: No such file or directory
libabi/src/xpat.c:23: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘XPAT_ParserCreate’
libabi/src/xpat.c:28: error: expected ‘)’ before ‘parser’
libabi/src/xpat.c:33: error: expected ‘)’ before ‘parser’
libabi/src/xpat.c:38: error: expected ‘)’ before ‘parser’
libabi/src/xpat.c:43: error: expected ‘)’ before ‘parser’
libabi/src/xpat.c:48: error: expected ‘)’ before ‘parser’
libabi/src/xpat.c:53: error: expected ‘)’ before ‘parser’
libabi/src/xpat.c:58: error: expected ‘)’ before ‘parser’
libabi/src/xpat.c:63: error: expected ‘)’ before ‘parser’
libabi/src/xpat.c:68: error: expected ‘)’ before ‘parser’
libabi/src/xpat.c:73: error: expected ‘)’ before ‘parser’
libabi/src/xpat.c:78: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘XPAT_GetCurrentLineNumber’
libabi/src/xpat.c:83: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘XPAT_GetCurrentColumnNumber’
libabi/src/xpat.c:88: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘XPAT_GetCurrentByteIndex’
libabi/src/xpat.c:93: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
libabi/src/xpat.c:98: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
gmake: *** [out/libmakemkv.so.1.full] Error 1
Any suggestions?
Thanks,
Bill
Romansh
Re: MakeMKV v1.8 on CentOS 6.4 linux - compile errors
#2 Post by Romansh » Thu Apr 18, 2013 8:57 am
Missing expat-dev (maybe expat-devel) package?
ngc4013
#3 Post by ngc4013 » Thu Apr 18, 2013 10:51 pm
That was it! The install was missing the expat-devel.x86_64 which I failed to go back to look at when testing for libexpat-devel noted in the version announcement.
Package is installed, and I am doing a test run right now to see what this new computer can do compared to my old one.
Thanks for your suggestion.
Bill
ngc4013
#4 Post by ngc4013 » Sat Apr 20, 2013 3:56 am
So now I am confused. Website I thought said the trial period was 60 days. After compiling the tool says 30 days, which is still okay. But tonight the tool says it is expired. Total run time was maybe about 45min max. So what happened to the 30 or 60 days?
paulster
#5 Post by paulster » Sat Apr 20, 2013 4:06 am
Read the announcements forum and all will become clear.
ngc4013
#6 Post by ngc4013 » Sat Apr 20, 2013 7:41 pm
I just had not gone deep enough, but I have figured it out. Running fine now without messages. Thanks for your help.
