Track Following Error, WotW
squareshot
#1 Post by squareshot » Mon Apr 15, 2013 11:06 pm
Hi!
I'm new here, so I hope I don't elicit any RTFM responses!
I only recently transitioned to Blu-Ray, never had problems with DVD's.
My first effort was to rip my first Blu-Ray, the re-issue of "Serial Experiments Lain," and this was completely successful.
This is my second attempt with a Blu-Ray ("War of the Worlds"), and I'm getting an error at around 20GB of output.
There are 2 candidate movie streams, and both of them fail similarly.
On loading, 00058.m2ts can't be read, but- according to another program (BDtoAVCHD)- that file is not included in either candidate movie stream.
The problem occurs with 00055.m2ts
I'm using a Digistor (Matshita) external BD/DVD writer on Windows 7. I also tried the demo version on Mac OSX 10.7.5 with the same drive and got the same errors.
Any insight (disc problem, drive problem, other problem) and/or advice would be greatly appreciated!
The output is as follows:
MakeMKV v1.8.0 win(x64-release) started
File 00020.mpls was added as title #0
Title #00002.mpls has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01000.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01001.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.mpls was added as title #1
Title #00000.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00056.m2ts was added as title #2
File 00057.m2ts was added as title #3
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00058.m2ts' at offset '0'
Title #00058.m2ts was skipped
File 00059.m2ts was added as title #4
File 00060.m2ts was added as title #5
File 00061.m2ts was added as title #6
File 00062.m2ts was added as title #7
File 00063.m2ts was added as title #8
File 00064.m2ts was added as title #9
File 00065.m2ts was added as title #10
File 00066.m2ts was added as title #11
File 00067.m2ts was added as title #12
Title #00068.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01000.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01001.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory H:/Video/War_Of_The_Worlds
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00055.m2ts' at offset '25611399168'
Failed to save title 1 to file H:/Video/War_Of_The_Worlds/War_Of_The_Worlds_t01.mkv
0 titles saved, 1 failed
crowfax
Re: Track Following Error, WotW
#2 Post by crowfax » Tue Apr 16, 2013 12:53 am
This error indicates that your drive can't read the disc.
This can have 1 of 2 causes: bad disc or failing drive.
Blu-ray does not have any copy protection that causes read issues, so this is not a copy protection issue.
#3 Post by mike admin » Tue Apr 16, 2013 5:26 am
squareshot wrote:Hi!
I really can't resist :) Please see /faq/item/7/catid/6
squareshot
#4 Post by squareshot » Tue Apr 16, 2013 11:23 am
Thank you both for the quick replies (and for being merciful! :oops: )
I'll try cleaning the disc again, increase the read retry count, and hope for the best.
