Orig thread: http://www.makemkv.com/forum2/viewtopic ... 77&start=0
HI.
I have two blu-ray rips, Transformers 2 and Half-blood Prince. Both ripped with MakeMKV 1.4.11. Neither one plays well on the wdtv. They start off OK, but then the video gets choppy, and the audio drops out. Specs are below. All my HD-DVD rips play fine (created with dumphd & eac3to).
I am running b-rad 0.5.8.1 on the WDTV.
I am trying to figure out if this is a makemkv issue with the MKV creation, or a problem/limitation of the WDTV. I also tried running the MKV thru tsmuxer, and the resulting M2TS did not play at all on the WDTV.
One further note on Half-Blood Prince: Funny thing I noticed about Half-Blood prince this morning: It played well from about the time Harry met Professor Slughorn (possibly earlier, I was in and out of the room until then) all the way up to the point where the camera moved thru the windows and into the Weasley twins store. Right where the camera moves thru the window some fireworks start inside the store, and then it got choppy and I lost sound.
Any help or ideas are appreciated?
Thanks,
John
p.s. I am also going to try plugging a USB HD directly into my WDTV (hopefully tonite), and see if my network is the problem, even tho it has not been an issue with all my non-BR rips, including HD-DVD 1080p movies.
Transformers 2:
General
Complete name : /media/backup/Movies2/Transformers-ROTF.mkv
Format : Matroska
File size : 39.0 GiB
Duration : 2h 29mn
Overall bit rate : 37.3 Mbps
Encoded date : UTC 2010-01-09 15:17:03
Writing application : MakeMKV v1.4.10 beta linux(x64-release)
Writing library : libmakemkv v1.4.10 beta (0.7.7/0.8.1) x86_64-manbo-linux-gnu
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 29mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA
Codec ID : A_DTS
Duration : 2h 29mn
Bit rate mode : Variable
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Title : HD Lossless
Language : English
Audio #2
Format : DTS
Codec ID : A_DTS
Duration : 2h 29mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Stream size : 1.58 GiB (4%)
Title : 3/2+1
Language : EnglishPrince:
General
Complete name : /home/john/Download/DVDRips/halfblood prince/title01.mkv
Format : Matroska
File size : 21.6 GiB
Duration : 2h 33mn
Overall bit rate : 20.1 Mbps
Encoded date : UTC 2010-01-16 14:59:17
Writing application : MakeMKV v1.4.11 beta linux(x64-release)
Writing library : libmakemkv v1.4.11 beta (0.7.7/0.8.1) x86_64-manbo-linux-gnu
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 2h 33mn
Colorimetry : 4:2:0
Audio #1
Format : TrueHD
Codec ID : A_TRUEHD
Codec ID/Info : Dolby TrueHD
Duration : 2h 33mn
Title : 5.1
Language : English
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 33mn
Bit rate : 640 Kbps
Stream size : 703 MiB (3%)
Title : 3/2+1
Language : English
