Problem with forced subtitles
Serhio
Post by Serhio »
Hi. Tnx for your program.
I have a problem on one disk.
The Hobbit: An Unexpected Journey (2012) {2-Disc Edition} Blu-ray 3D CEE 1080p AVC DD5.1
I select only Russian audio and Russian forced subtitles. MakeMKV make it work without errors. But during playing mkv file I see Russian and English forced subtitles at the same time. What can I do in this situation?
Smithcraft
Re: Problem with forced subtitles
Post by Smithcraft »
Try remuxing it with mkvtoolnix to remove the undesired subtitle streams, as well as anything else that you might want to get rid of.
SC
Serhio
Post by Serhio »
Well, mkvtoolnix see only one subtitle stream. :(
Smithcraft
Could you be so kind as to post the output from a MediaInfo scan of your Hobbit rip?
SC
Romansh
Post by Romansh »
If it's anything like Lord of the Rings extended on Blu-ray, the English forced subtitles are rendered over the video, not a separate track - so you can't turn them off.
Smithcraft
That's my guess also.
SC
Serhio
Post by Serhio »
:oops: It's my mistake. It is hardsub in English in video. I am sorry. False alarm. :oops:
