Life of Pi Embedded Subtitle automatically - newbie
mdh44109
#1 Post by mdh44109 » Wed Apr 10, 2013 6:52 am
I just used the current version 1.8 of makemkv for the first time with Life of Pi Bluray. It put the english subtitle in automatically. Even when I unchecked all of the subtitle checkboxes, the subtitle was still there. The option was greyed out using either Windows Media Player or Powerdvd 12 Ultra. So I have no way to disable it.
Should I try using handbrake to convert it to another format, If yes, then would there be any loss of video quality? What format would be the best for Bluray.
Smithcraft
Re: Life of Pi Embedded Subtitle automatically - newbie
#2 Post by Smithcraft » Wed Apr 10, 2013 7:15 am
You could use mkvtoolnix to remux it and remove the English subtitles.
SC
Chetwood
#3 Post by Chetwood » Thu Apr 11, 2013 6:06 am
mdh44109 wrote:The option was greyed out using either Windows Media Player or Powerdvd 12 Ultra. So I have no way to disable it.
Not with these crappy players apparently. What happens when you watch the MKV in VLC or MPC-HC?
setarip_old
#4 Post by setarip_old » Tue May 14, 2013 9:08 pm
Hi!
I believe it's been noted elsewhere that one of the .MPLS files (either 800 or 802) contains burned in subtitles (part of the video)...
