Cant find drive still an issue in 1.4.11
uslaves
#1 Post by uslaves » Wed Jan 13, 2010 2:51 am
i read through the previous posts and it sounded like this could have been fixed in release 4.1.9 but i still get it. mine is lightly different as it doesn't have the part about administrative privileges i've seen with others posts. on startup i get the following in the log file:
Debug log started at Wed Jan 13 02:41:51 2010 , written by MakeMKV v1.4.11 beta win(x64-release)
001014:000000:0000 MakeMKV v1.4.11 beta win(x64-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\Server/MakeMKV_log.txt
005042:000000:0000 The program can't find any usable optical drives.
i'm using win7 default drivers
just wondering if a fix was near
thanks
Re: Cant find drive still an issue in 1.4.11
#2 Post by mike admin » Wed Jan 13, 2010 5:50 am
you need to run the program as administrator, are you?
uslaves
#3 Post by uslaves » Sat Jan 16, 2010 1:29 am
yes
uslaves
#4 Post by uslaves » Sat Jan 16, 2010 1:31 am
i am rdc into the machine if that makes any difference. but double checked and i am logging in as the administrator
#5 Post by mike admin » Sun Jan 17, 2010 9:24 am
What OS do you use?
uslaves
#6 Post by uslaves » Tue Jan 19, 2010 2:29 am
windows 7 ultimate - 64bit
#7 Post by mike admin » Tue Jan 19, 2010 8:16 am
if you have UAC enabled, which is default setting, you must right click the makemkv icon and select "run as administrator"
uslaves
#8 Post by uslaves » Wed Jan 20, 2010 1:43 am
problem solved. thanks so much for your help. i didn't realize i had to run as administrator if i was already logged in as administrator.
thanks again, and as i've said before, great little program.
