All backups suddenly failing EDIT: Fixed
JerkyChew
Post by JerkyChew » Sun Mar 31, 2013 1:35 am
It has been a while since I've tried ripping anything, but suddenly anything I try is failing. It starts scanning files and then just fails. I've turned on debugging and here are the logs:
MakeMKV v1.8.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\matt/MakeMKV_log.txt
Backing up disc into folder "L:\rips/backup/HOBBIT_PART1"
DEBUG: Code 0 at No1XHX!LPJS?*I\!Uf+::121266672
DEBUG: Code 0 at No1XHX!LPJS?*I\!Uf+::213143048
Backup failed
One thing I noticed was that some of the destination file/folder settings used a forward slash instead of a backslash. I tried changing them to backslashes but it didn't seem to make a difference. I'm running Windows 7 64-bit on a Dell XPS desktop Core i7. The last two titles I've tried were Kill Bill volume 1 and The Hobbit.
EDIT: Man, I'm dumb. I reset the output folder to the defaults and it worked without issue. Then I realized that my output folder was set to an external drive that was no longer hooked up. I hope others learn from my mistake. :D
