Hi
ive installed the trail of arcsoft TMT 6.
where can i find the dtshddec.dll ?
ive found a dll in D:\Program Files (x86)\ArcSoft\TotalMedia Theatre 6\Codec, it is called dtsdecoderdll.dll .
is that the right one?
greetings ftxhifi
DTS-HD where can i find the DLL for decoding?
Re: DTS-HD where can i find the DLL for decoding?
Bit late, but anyway..
Yeah, that should be the right one. Copy it into the MakeMKV folder, then go into "Preferences", "Advanced"(tab), and the option dtshddec.dll location, click the page next to it, and select the copied DLL file. Click ok, maybe restart MakeMKV just in case, but then it should be ok.
