Unable to copy at all using either Windows or a Mac
chrispycrutch
Post by chrispycrutch »
Hi, apologies for a newbie question here and many thanks for your help in advance.
Am running makemkv version 1.8.0 on both my windows laptop and my imac. I have bought and am using a generic bluray reader which is recognised by both machines.
I have tried ripping a Take That Concert (I know :lol: )and then ripping 'Life of Pi'.
I start the process off in either machine and things seem fine but I keep getting the same result: '0 items saved, 1 item failed'
If someone could be kind enough to point me in the right direction that would be great. Many Thanks
Log of the last copy I tried detailed below.
Debug log started at Fri Mar 29 09:49:59 2013 , written by MakeMKV v1.8.0 win(x64-release)
001005:0000 MakeMKV v1.8.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\The Brownies/MakeMKV_log.txt
003305:0000 AACS directory not present, assuming unencrypted disc
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
003307:0000 File 00000.mpls was added as title #0
001003:0020 DEBUG: Code 233 at rvYGfAyQuUmIqKvq7/ayRKJm:0
005014:0000 Saving 1 titles into directory F:/Life of Pi
001003:0020 DEBUG: Code 3221225628 at T-dESS}?aU[R%EZOj6)xbp@q<:121263521
001003:0020 DEBUG: Code 3221225628 at oI3NaUU%cLOX-K56:29393953
001003:0020 DEBUG: Code 2 at H1D6?(+&.PY0,5-F:121268995
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '372123648'
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '383133696'
001003:0020 DEBUG: Code 0 at a@.8T')HOvTQ SNc}u*O:121262739
001003:0020 DEBUG: Code 0 at lj^jzws<Rp!qx54Y.!:S:121261888
001003:0020 DEBUG: Code 0 at a@.8T')HOvTQ SNc}u*O:213130743
001003:0020 DEBUG: Code 187077 at a@.8T')HOvTQ SNc}u*O:29393332
001003:0020 DEBUG: Code 0 at e+!PDn"":im09l/RAaww*:213134584
001003:0020 DEBUG: Code 0 at vW^!iGh9{?_'7^[\*nJ:29395931
005003:0000 Failed to save title 0 to file F:/Life of Pi/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Fri Mar 29 10:37:29 2013
Re: Unable to copy at all using either Windows or a Mac
That indicates that the drive couldn't read part of the disk. Since a rip is intended to make a "bit for bit" copy, MakeMKV won't skip over flaws like a hardware player would.
First step would be to try cleaning the disk. Personally, I do this with Pledge Furniture Polish and a soft cotton towel, because the wax in it will fill in small scratches, but that's entirely up to you.
chrispycrutch
Hi and thanks for the reply.
Did clean discs (discs have only ever been viewed once in my PS3) with a cotton cloth after the first few failures and tried it again with the same results.
Could it be the drive thats faulty at all, I am not the most technically gifted person so wouldnt know how to tell?
The test to see if it is the drive would be to rip a different disk, and see if it, too, has unrecoverable read errors, as well as trying the SAME disk to see if the errors are in the same place, or move around. Sometimes, a drive will have seek failures, and not get to where the software expects it to be.
