0 titles saved, 1 failed
4everyoung
#1 Post by 4everyoung » Thu Mar 28, 2013 3:46 pm
I'm trying to convert ISO file to MKV. All seems to work except one with this error:
MakeMKV v1.8.0 win(x64-release) started
Debug logging enabled, log will be saved as H:\/MakeMKV_log.txt
Title #0 was added (16 cell(s), 1:37:56)
Saving 1 titles into directory C:/Video/NEW
DBG ASSERT: K=@Gw8]RZQ|K3$m[R0eGXw_Qz%JrcPkk at 4s0J<~}_*Wo4=EGy:121263015
DEBUG: Code 27 at vW^!iGh9{?_'7^[\*nJ:121267063
DEBUG: Code 149 at vW^!iGh9{?_'7^[\*nJ:29398967
DEBUG: Code 1 at vW^!iGh9{?_'7^[\*nJ:121267109
DEBUG: Code 0 at e+!PDn"":im09l/RAaww*:213134584
Failed to save title 0 to file C:/Video/NEW/title00.mkv
Help! Tks.
PS: The fastest converter I've seen so far :D
setarip_old
Re: 0 titles saved, 1 failed
#2 Post by setarip_old » Fri Mar 29, 2013 12:57 am
Hi!
Quite possibly a dirty or physically damaged disc - or an incorrectly made .ISO image file.
Try using the original commercial disc as your source, instead of the .ISO image file that you made from the original disc...
#3 Post by mike admin » Fri Mar 29, 2013 8:39 am
4everyoung wrote:Debug logging enabled, log will be saved as H:\/MakeMKV_log.txt
Please send this file to support@makemkv.com - it has additional information.
