0 titles saved, 1 failed
4everyoung
Post by 4everyoung » Thu Mar 28, 2013 3:46 pm
I'm trying to convert ISO file to MKV. All seems to work except one with this error:
MakeMKV v1.8.0 win(x64-release) started
Debug logging enabled, log will be saved as H:\/MakeMKV_log.txt
Title #0 was added (16 cell(s), 1:37:56)
Saving 1 titles into directory C:/Video/NEW
DBG ASSERT: K=@Gw8]RZQ|K3$m[R0eGXw_Qz%JrcPkk at 4s0J<~}_*Wo4=EGy:121263015
DEBUG: Code 27 at vW^!iGh9{?_'7^[\*nJ:121267063
DEBUG: Code 149 at vW^!iGh9{?_'7^[\*nJ:29398967
DEBUG: Code 1 at vW^!iGh9{?_'7^[\*nJ:121267109
DEBUG: Code 0 at e+!PDn"":im09l/RAaww*:213134584
Failed to save title 0 to file C:/Video/NEW/title00.mkv
Help! Tks.
PS: The fastest converter I've seen so far :D
setarip_old
Re: 0 titles saved, 1 failed
Post by setarip_old » Fri Mar 29, 2013 12:57 am
Hi!
Quite possibly a dirty or physically damaged disc - or an incorrectly made .ISO image file.
Try using the original commercial disc as your source, instead of the .ISO image file that you made from the original disc...
Post by mike admin » Fri Mar 29, 2013 8:39 am
4everyoung wrote:Debug logging enabled, log will be saved as H:\/MakeMKV_log.txt
Please send this file to support@makemkv.com - it has additional information.
