Possible Mastering Error - Urusei Yatsura Volume 26
Tolken
Post by Tolken »
Disk is physically fine, plays fine, and copies fine. Previous disks were successful
The fails happen within the first 50mb.
MakeMKV v1.8.0 win(x86-release) started
Debug logging enabled, log will be saved as MakeMKV_log.txt
Title #0 was added (21 cell(s), 1:42:28)
Title #1 was added (5 cell(s), 0:25:35)
Title #2 was added (5 cell(s), 0:25:37)
Title #3 was added (5 cell(s), 0:25:36)
Title #4 was added (5 cell(s), 0:25:35)
Title #5 has length of 33 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Saving 5 titles into directory C:/Video/UY_VOL_26
DEBUG: Code 41 at >@p$rn&P =p[TS S3"g:121267063
DEBUG: Code 149 at >@p$rn&P =p[TS S3"g:29398967
DEBUG: Code 15 at >@p$rn&P =p[TS S3"g:121267109
DEBUG: Code 0 at Zk,3A'n2JUXm}Q(]]aO%,:213134584
Failed to save title 0 to file C:/Video/UY_VOL_26/title00.mkv
Failed to save title 1 to file C:/Video/UY_VOL_26/title01.mkv
DEBUG: Code 33 at >@p$rn&P =p[TS S3"g:121267063
DEBUG: Code 0 at >@p$rn&P =p[TS S3"g:121262417
DEBUG: Code 0 at >@p$rn&P =p[TS S3"g:121262210
DEBUG: Code 0 at Zk,3A'n2JUXm}Q(]]aO%,:213134308
DEBUG: Code 0 at Zk,3A'n2JUXm}Q(]]aO%,:121266534
DEBUG: Code 0 at !1W/_[H3hE03\>,YE\H:121262555
DEBUG: Code 0 at !1W/_[H3hE03\>,YE\H:213132054
DEBUG: Code 0 at !1W/_[H3hE03\>,YE\H:121263659
DEBUG: Code 0 at !1W/_[H3hE03\>,YE\H:121265384
DEBUG: Code 0 at ,=J!k~6|ROD~RX`D:213130122
DEBUG: Code 0 at Y8gd!KZ")/GH5]%RWb:121266258
DEBUG: Code 0 at Y8gd!KZ")/GH5]%RWb:213134952
Failed to save title 2 to file C:/Video/UY_VOL_26/title02.mkv
DEBUG: Code 39 at >@p$rn&P =p[TS S3"g:121267063
Failed to save title 3 to file C:/Video/UY_VOL_26/title03.mkv
DEBUG: Code 24 at >@p$rn&P =p[TS S3"g:121267063
Failed to save title 4 to file C:/Video/UY_VOL_26/title04.mkv
0 titles saved, 5 failed
Re: Possible Mastering Error - Urusei Yatsura Volume 26
There is another thread on this here. Disks 26-30 cannot be read properly by MakeMKV, due to problems with the way they're mastered. You can find it by searching for "urusei". Disks 1-25 and 31-50 are apparently OK.
But, there wasn't much data for Mike to work with to work around it, since only one person had a legal copy. Been trying to find one myself... but not willing to pay $1200 for the series. :roll:
For what it is worth, if you have a version of Handbrake that is set up to be able to read DVDs directly (the Mac version, or Windows/Linux with the proper additional libraries added), it CAN read the problem disks directly.
Tolken
Post by Tolken »
Woodstock wrote: But, there wasn't much data for Mike to work with to work around it, since only one person had a legal copy. Been trying to find one myself... but not willing to pay $1200 for the series. :roll: .
Netflix is the best source for OOP anime (They even have a complete collection of MI). I don't remember if Mike is in the US, but it's the cheapest way to get ahold of an actual legit disk.
I've used them previously to obtain disks when my own copies didn't read due to damage or faulty authoring.
(This is actually why I was pretty sure this UY disk was a mastering error, I actually thought the problem was with my original disk then it did the same thing for the Netflix disk that came in today)
PS: Thank you very much for letting me know about the range it encompasses, that'll make my life easier.
You probably should jump in on the thread from November on these disks... The last thing posted on it was a request from Mike for log information for each of the problem disks, but the original poster did not respond.
As for Netflix, I was working my way through the series at the time, and the problem disks came up in the queue about that time. I ran some tests on a couple of them, and found that they did exhibit the behavior (files didn't complete).
I use NF a little differently - to find out if a series is worth buying. NF cost me about $3K last year, over and above the subscription costs, and not including the shelving units.... :roll:
Post by mike admin »
Please send this log file to support@makenkv.com - it should have additional information needed for debug. Errors like these can be worked around without the need to wait for the next version. But I do need log files first.
