1.8.0 not recognizing drives
stevesnell
Post by stevesnell » Wed Mar 20, 2013 3:43 am
I've been using 1.8 for awhile with no problems. Sent my MacPro in for a memory problem (had to remove 4GB of bad RAM, leaving 6GB) and now, with no other changes that I'm aware of, MakeMKV doesn't recognize either my SuperDrive or my OWC Blu-ray drive. Tried both USB 2.0 and Firewire 400, nothing. However, I can see the disk on my desktop. Any help appreciated.
Steve
Smithcraft
Re: 1.8.0 not recognizing drives
Post by Smithcraft » Wed Mar 20, 2013 4:23 am
Try opening MakeMKV after the disc has mounted to the Finder.
SC
stevesnell
Post by stevesnell » Wed Mar 20, 2013 12:42 pm
Smithcraft wrote:Try opening MakeMKV after the disc has mounted to the Finder.
SC
Yes, I read the other threads about this trick but it unfortunately didn't work in my case.
Steve
Smithcraft
Post by Smithcraft » Wed Mar 20, 2013 8:31 pm
What version os OS X?
SC
stevesnell
Post by stevesnell » Thu Mar 21, 2013 3:27 am
Smithcraft wrote:What version os OS X?
SC
10.8.3. RAM is back in (10GB).
Steve
This is what I see...
Post by mike admin » Fri Mar 22, 2013 8:14 am
This is different error. Does it ever go past this screen? Do you have DASPI installed?
stevesnell
Post by stevesnell » Fri Mar 22, 2013 1:51 pm
mike admin wrote:This is different error. Does it ever go past this screen? Do you have DASPI installed?
I did but reinstalled and that fixed the problem. Thank you so much!
Steve
stevesnell
Post by stevesnell » Sat Mar 23, 2013 6:06 pm
I spoke too soon. When I reboot the computer, MakeMKV works one time. When I complete a DVD and then try to eject the disk, it won't eject from within MakeMKV. When I quit, it asks if I want to cancel the current operation. When I relaunch, it doesn't recognize the drives again. Frustrating...
Steve
stevesnell
Post by stevesnell » Wed Mar 27, 2013 10:40 pm
New information. When I reboot, I can see both my superdrive and blu-ray drive through system profiler. MakeMKV will works properly. However. After I quit processing the first disk and attempt to relaunch, MakeMKV does not work and neither the superdrive or blu-ray drive can be seen by system profiler.
Steve
Post by mike admin » Thu Mar 28, 2013 9:09 am
Please try following:
1. Eject discs from all drives, Reboot, launch MakeMKV, exit MakeMKV. Check drives operational (insert disc, see in finder)
2. Eject discs from all drives, Reboot, launch MakeMKV, press big button to open disc, close MakeMKV. Check the drives.
3. Eject discs from all drives, Reboot, launch MakeMKV, press big button to open disc, eject disc from within MakeMKV, close MakeMKV. Check the drives.
stevesnell
Post by stevesnell » Mon Apr 01, 2013 1:07 pm
1. Eject discs from all drives, Reboot, launch MakeMKV, exit MakeMKV. Check drives operational (insert disc, see in finder) PASS
2. Eject discs from all drives, Reboot, launch MakeMKV, press big button to open disc, close MakeMKV. Check the drives. PASS
3. Eject discs from all drives, Reboot, launch MakeMKV, press big button to open disc, eject disc from within MakeMKV, close MakeMKV. Check the drives. PASS
Seems to be working now. I'll keep testing. Thanks.
Steve
