1.8.0 not recognizing drives
stevesnell
I've been using 1.8 for awhile with no problems. Sent my MacPro in for a memory problem (had to remove 4GB of bad RAM, leaving 6GB) and now, with no other changes that I'm aware of, MakeMKV doesn't recognize either my SuperDrive or my OWC Blu-ray drive. Tried both USB 2.0 and Firewire 400, nothing. However, I can see the disk on my desktop. Any help appreciated.
Steve
Steve
Smithcraft
Re: 1.8.0 not recognizing drives
Try opening MakeMKV after the disc has mounted to the Finder.
SC
SC
stevesnell
Yes, I read the other threads about this trick but it unfortunately didn't work in my case.Smithcraft wrote:Try opening MakeMKV after the disc has mounted to the Finder.
SC
Steve
Smithcraft
What version os OS X?
SC
SC
stevesnell
10.8.3. RAM is back in (10GB).Smithcraft wrote:What version os OS X?
SC
Steve
- This is what I see...
- makemkv.jpg (27.14 KiB) Viewed 21017 times
- Contact:
This is different error. Does it ever go past this screen? Do you have DASPI installed?
stevesnell
I did but reinstalled and that fixed the problem. Thank you so much!mike admin wrote:This is different error. Does it ever go past this screen? Do you have DASPI installed?
Steve
stevesnell
I spoke too soon. When I reboot the computer, MakeMKV works one time. When I complete a DVD and then try to eject the disk, it won't eject from within MakeMKV. When I quit, it asks if I want to cancel the current operation. When I relaunch, it doesn't recognize the drives again. Frustrating...
Steve
Steve
stevesnell
New information. When I reboot, I can see both my superdrive and blu-ray drive through system profiler. MakeMKV will works properly. However. After I quit processing the first disk and attempt to relaunch, MakeMKV does not work and neither the superdrive or blu-ray drive can be seen by system profiler.
Steve
Steve
- Contact:
Please try following:
1. Eject discs from all drives, Reboot, launch MakeMKV, exit MakeMKV. Check drives operational (insert disc, see in finder)
2. Eject discs from all drives, Reboot, launch MakeMKV, press big button to open disc, close MakeMKV. Check the drives.
3. Eject discs from all drives, Reboot, launch MakeMKV, press big button to open disc, eject disc from within MakeMKV, close MakeMKV. Check the drives.
stevesnell
1. Eject discs from all drives, Reboot, launch MakeMKV, exit MakeMKV. Check drives operational (insert disc, see in finder) PASS
2. Eject discs from all drives, Reboot, launch MakeMKV, press big button to open disc, close MakeMKV. Check the drives. PASS
3. Eject discs from all drives, Reboot, launch MakeMKV, press big button to open disc, eject disc from within MakeMKV, close MakeMKV. Check the drives. PASS
Seems to be working now. I'll keep testing. Thanks.
Steve
Steve
