HD Audio 7.1 being backed up as 5.1 only
groverj3
Re: HD Audio 7.1 being backed up as 5.1 only
Thanks for the info. This finally makes logical sense. I think it would best if I alerted the handbrake people to this bug. It is a nightly build after all and nothing is guaranteed to be working 100% correctly.
Smithcraft
I think you already did.
SC
SC
Johnny569
Hey the same thing just happened to me.
I have the Stargate 15th Anniversary Edition blu-ray with 7.1 DTS-HD MA
I backed up the main movie with MakeMKV selecting the lossless audio.
VLC Media Player only sees 5.1 DTS-HD
XBMC only sees 5.1 DTS-HD
However, PowerDVD 12 sees the full DTS 7.1 Audio. Looks like the problem is VLC and XBMC not recognizing 7.1 audio.
Madfonzy
I've come across the same issues while using handbrake and viewing thru xbmc. Both state 5.1 passthru but when I stream it to my AVR it says DTS-HD MSTR 7.1. I also checked it with my ears and yes there is sound coming from the two rear speakers. So it seems it is just the software not displaying 7.1.
It might be time for you to upgrade your AVR
The 7.1 adds to the sound effects
