just finished ripping my bluray collection (about 200 disks) to hdd (full disk backup). Last step is to have a closer look at the disks with errors in the LOGS.
For the first two I'm not sure if this a problem, cause the backup seemed to finish normally.
Debug log started at Fri Mar 15 11:11:31 2013 , written by MakeMKV v1.8.0 win(x64-release)
001005:0000 MakeMKV v1.8.0 win(x64-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als C:\Users\admin/MakeMKV_log.txt
005072:0000 Disk in Ordner kopieren "G:\_makemkv/backup/MEMENTO"
001003:0020 DEBUG: Code 0 at `,M]S\?g0QIc\0 ;(:213131318
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=r5YFhuGAm5KzwrfbxfDaXMIwteAM/NCGhQj5dkiGaKCWRea5CAuVMknspqnRdkjWcsJYYmcuMkRecrwnvZ2O+o0fNIsBd5BvGEW0DCMuFIkLRYd6apEUATL3LOob5FZX99O304GlANlRR6IRDv5aNoczM10vfWaH3Q==
DCE=4EQ/VUOvyIA/JehTtlJopVpC+VVEE6RKKIIpGaxInTUvpYHUixeEEqcCITGKkXQe4s+CZvp0g3x4y912/3QCZEQLM4eVCbk3hoPBONrEFkKghviC5OPg24/SwOAEgT5PSAFI2/AYBbkY98IHU77Ow9ZNP0raSCF9FA==
005085:0000 Inhalte-Hashtabelle geladen, ?berpr?fe Integrit?t der M2TS-Dateien.
005070:0080 Backup beendet
005081:0104 Backup beendet.
Application exited at Fri Mar 15 13:15:53 2013
Debug log started at Fri Mar 15 13:16:35 2013 , written by MakeMKV v1.8.0 win(x64-release)
005072:0000 Disk in Ordner kopieren "G:\_makemkv/backup/APOCALYPTO"
DCE=5PNrGdDk2vEHBfZAj7xc5+wzwdCH+xN2fmpMk9zlfpws2Qdj4Lb0naIbwRKdR8GGIMTMbAYuHSgc3XLR/gbibvkOu6+E8MxldC3ftnKwcMznq4ij6SVx4xdVr17R6690ja4OaI+oOTLMuzaf9PtISexm0xi480QpZA==
DCE=lCihFItBciL4QZZ9ws6USKui3qxh/2JmTjpR9Qvv5OoZnUa0B/RfV5BmQEb3qx4hxuZDAQe56/RlVf+zsf5Carn08p8ccYnOIc9U37s0KOSJ5/P2mxgoqa8RD2GmrGXuZzXJ759O7V/T3GdEvhmy4u/yKZmifvGPvw==
Application exited at Fri Mar 15 14:01:53 2013
So problem, no problem or somewehere in between?
DebugCode Apocalypto / Memento
- Contact:
Re: DebugCode Apocalypto / Memento
This error means that MakeMKV failed to parse metadata / cover art from blu-ray. Your backups are absolutely fine. Please send contents of /BDMV/META/DL directory from both discs to support@makemkv.com for analysis.
LeftieFOM
Hello Mike,
thanks for your answer. Just sent the requested files to you. Hope this helps. If you need more infos, let me know.
Leftie
Leftie
