DTS-HD HRA (XBR) decoding fails
holunder2
#1 Post by holunder2 » Thu Mar 14, 2013 4:13 pm
Hey,
DTS-HD MA decoding processes just fine with MakeMKV, but whenever I come across a BD with DTS-HD High Resolution Audio the conversation fails. MakeMKV stops on "1.1 K" and I can't abort the decoding, so I only can kill the program.
You can see my conversion profile here.
MakeMKV shows the audio stream as "Name: HRA XBR". I know, HRA is very rare, but the German distributor Constantin uses is on pretty much all of its releases.
Any idea? Thank you very much!
Re: DTS-HD HRA (XBR) decoding fails
#2 Post by mike admin » Fri Mar 15, 2013 7:31 am
Please send a test dump per /onlinehelp/testdump.html and make sure to select this DTS-HRA audio stream.
Romansh
#3 Post by Romansh » Sun Mar 17, 2013 6:27 pm
I have a similar issue reproducible by using mmdtsdec directly. Would sample raw DTS-HD streams be as good as, or better than, a test dump?
I can provide tracks from BD sources, as well as straight out of the DTS encoder.
holunder2
#4 Post by holunder2 » Sun Mar 17, 2013 6:50 pm
I have a stream for him too. Currently I am writing on the mail. (Well, not quite currently, but you understand).
#5 Post by mike admin » Sat Mar 23, 2013 9:06 am
Romansh wrote:I have a similar issue reproducible by using mmdtsdec directly. Would sample raw DTS-HD streams be as good as, or better than, a test dump?
Either one will do. Yes, please send the test streams.
Chetwood
#6 Post by Chetwood » Sat Mar 23, 2013 4:41 pm
Mhm, I've successfully converted some DTS-HRA tracks, even with older versions of MakeMKV.
marcusj0015
#7 Post by marcusj0015 » Mon Mar 25, 2013 1:11 am
Which conversion profile are you using? I had trouble with mine for awhile, and it worked fine with the default profile.
holunder2
#8 Post by holunder2 » Mon Mar 25, 2013 1:28 am
@marcusj0015:
The default one doesn't even decodes or converts anything to FLAC. The "FLAC" profile just copies the DTS-HD HRA stream. I've added this lines to my custom profile:
    <trackSettings input="DTSHD-stereo">
        <output outputSettingsName="flac-best"
                defaultSelection="$app_DefaultSelectionString">
        </output>
    </trackSettings>
    <trackSettings input="DTSHD-multi">
        </output>
    </trackSettings>
This seams to be the HRA stream, because with this lines MakeMKV displays for the HRA stream "Output format: FLAC audio ( Lossless conversion )". And then, like I have described it, it simply fails on decoding. I have sent Mike a mail with a HRA sample to reproduce this.
marcusj0015
#9 Post by marcusj0015 » Mon Mar 25, 2013 6:01 pm
Oh, so it's not even the lossless version that you're trying to convert to FLAC?
holunder2
#10 Post by holunder2 » Mon Mar 25, 2013 6:07 pm
@marcusj0015 Nope. DTS-HD High Resolution Audio is a "DTS+" between DTS and DTS-HD Master Audio. There are many BDs from some publishers that have only HRA and no lossless Master Audio.
