How to configure preference only with command line
-FX-RIDER-
I'm using the new 1.5.5 beta on an minimal ubuntu karmic installation. I'm using just makemkvcon, but I can't use Avatar, because I can't configure the folders for makeMKV. Is it possible to use something like a configfile which is automatically used by makeMKV? I need to configure whre makeMKV can find the SQV package.
- Contact:
Re: How to configure preference only with command line
The configuration file is ~/.MakeMKV/settings.conf . For svq path the setting name is bdplus_SvqDir . The easiest way would be edit preferences on another computer and copy the configuration file.
-FX-RIDER-
Hi mike,
thank you for the answer. Couldn't try it up to now. Can't you upload a "generic" config file which I could change for my purpose?
this is what mine looks like
skittle@Skittle-PC:~/.MakeMKV$ cat settings.conf
# MakeMKV settings file, written by MakeMKV v1.5.5 beta linux(x64-release)
aacs_KeyFilesDir = ""
app_DestinationDir = ""
app_Key = "T-o4vIHFtFMG0O4H5u0NT40YJcRLnfXk2j1O0Yiy3O6YrwbHga7kWEYays4AS6MTK9h9"
app_ShowDebug = "1"
bdplus_DumpDir = ""
bdplus_SvqDir = "/home/skittle/.MakeMKV"
-FX-RIDER-
Hi skittle,
thank you very much... worked like a charm.
Finally I'm able to watch Avatar...
You guys rock...
Problem solved!
You guys rock...
Problem solved!
what is the syntax for setting automatic svq download?
I am guessing it is app_UpdateEnable = "1"
