I have been unable to rip this movie, tried it in both CellWalk and CellTrim modes.
MakeMKV v1.8.0 win(x86-release) started
Drive BD-ROM ATAPI iHOS104 WL0D has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Calculated BUP offset for VTS #10 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
Calculated BUP offset for VTS #13 does not match one in IFO header.
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
CellTrim algorithm failed since title has only 2 chapters
Title #31 (0:11:44) was skipped due to navigation error
Title #32 (0:10:54) was skipped due to navigation error
Title #33 (0:10:54) was skipped due to navigation error
Title #34 (0:11:08) was skipped due to navigation error
Title #35 (0:11:05) was skipped due to navigation error
Title #36 (0:10:54) was skipped due to navigation error
Title #37 (0:11:08) was skipped due to navigation error
Title #38 (0:11:03) was skipped due to navigation error
Title #39 (0:22:32) was skipped due to navigation error
Title #40 (0:11:01) was skipped due to navigation error
Title #41 (0:11:10) was skipped due to navigation error
Title #42 (0:11:05) was skipped due to navigation error
Title #43 (0:11:09) was skipped due to navigation error
Title #44 (0:11:08) was skipped due to navigation error
Fake cells occupy 73% of the title - assuming fake title
Title #46 (0:10:09) was skipped due to navigation error
Cells 1-8 were removed from title start
Title #90 was added (6 cell(s), 0:02:47)
Title #91 was added (6 cell(s), 0:02:47)
Title #96 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 2 in VTS 11 is equal to title 1 and was skipped
Sponge Bob Season 6, Region 1 NTSC
crowfax
Re: Sponge Bob Season 6, Region 1 NTSC
If you think you have found a disc that MakeMKV can't open then please do this:
/faq/item/8
/faq/item/8
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
That line says that the drive being used won't let MakeMKV bypass the region coding. As it says, errors will follow. There is a link that will let you see if there is updated, region-free firmware for your drive.byoung wrote:Drive BD-ROM ATAPI iHOS104 WL0D has RPC protection that can not be bypassed. Change drive region or update drive firmware from ...... Errors likely to follow.
