Receiving an error when trying to rip title01 of The Waltons s02.d04 (s02.e10e11):
MakeMKV v1.8.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Randy/MakeMKV_log.txt
Opening files on harddrive at C:/DVDPrep/The.Waltons.s02.d04/VIDEO_TS
Calculated BUP offset for VTS #1 does not match one in IFO header.
Title #0 was added (14 cell(s), 2:28:24)
Title #1 was added (8 cell(s), 1:38:40)
Title #2 was added (6 cell(s), 0:49:44)
Title #3 has length of 12 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #4 has length of 12 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #5 has length of 21 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #5/1 has length of 11 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #5/2 was added (1 cell(s), 0:01:17)
Title #5/3 has length of 29 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Saving 1 titles into directory C:/DVDPrep
DEBUG: Code 11 at vW^!iGh9{?_'7^[\*nJ:121267063
DEBUG: Code 149 at vW^!iGh9{?_'7^[\*nJ:29398967
DEBUG: Code 3 at vW^!iGh9{?_'7^[\*nJ:121267109
DEBUG: Code 0 at e+!PDn"":im09l/RAaww*:213134584
Failed to save title 1 to file C:/DVDPrep/title01.mkv
0 titles saved, 1 failed
The Waltons s02.d04
The Waltons s02.d04
- MakeMKV_log.txt
- (797.46 KiB) Downloaded 670 times
setarip_old
Re: The Waltons s02.d04
Hi!
Likely a physically damaged or dirty disc...LIBMKV_TRACE: Exception: Error while reading input
Had no errors while copying the disc first with Clone DVD.setarip_old wrote:Hi!Likely a physically damaged or dirty disc...LIBMKV_TRACE: Exception: Error while reading input
Randy
ToxicDreamz
The Waltons s02.d04
That doesn't mean the disk shouldn't be cleaned. You can also try setting the read retry count to 25 instead of the default 5 in the preferences.repstein wrote:Had no errors while copying the disc first with Clone DVD.setarip_old wrote:Hi!Likely a physically damaged or dirty disc...LIBMKV_TRACE: Exception: Error while reading input
Randy
