Sponge Bob Season 6, Region 1 NTSC
byoung
Post by byoung » Sun Mar 10, 2013 7:06 pm
I have been unable to rip this movie, tried it in both CellWalk and CellTrim modes.
MakeMKV v1.8.0 win(x86-release) started
Drive BD-ROM ATAPI iHOS104 WL0D has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Calculated BUP offset for VTS #10 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
Calculated BUP offset for VTS #13 does not match one in IFO header.
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
CellTrim algorithm failed since title has only 2 chapters
Title #31 (0:11:44) was skipped due to navigation error
Title #32 (0:10:54) was skipped due to navigation error
Title #33 (0:10:54) was skipped due to navigation error
Title #34 (0:11:08) was skipped due to navigation error
Title #35 (0:11:05) was skipped due to navigation error
Title #36 (0:10:54) was skipped due to navigation error
Title #37 (0:11:08) was skipped due to navigation error
Title #38 (0:11:03) was skipped due to navigation error
Title #39 (0:22:32) was skipped due to navigation error
Title #40 (0:11:01) was skipped due to navigation error
Title #41 (0:11:10) was skipped due to navigation error
Title #42 (0:11:05) was skipped due to navigation error
Title #43 (0:11:09) was skipped due to navigation error
Title #44 (0:11:08) was skipped due to navigation error
Fake cells occupy 73% of the title - assuming fake title
Title #46 (0:10:09) was skipped due to navigation error
Cells 1-8 were removed from title start
Title #90 was added (6 cell(s), 0:02:47)
Title #91 was added (6 cell(s), 0:02:47)
Title #96 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 2 in VTS 11 is equal to title 1 and was skipped
crowfax
Re: Sponge Bob Season 6, Region 1 NTSC
Post by crowfax » Mon Mar 11, 2013 4:53 pm
If you think you have found a disc that MakeMKV can't open then please do this:
/faq/item/8
Post by Woodstock » Tue Mar 12, 2013 1:28 am
byoung wrote:Drive BD-ROM ATAPI iHOS104 WL0D has RPC protection that can not be bypassed. Change drive region or update drive firmware from ...... Errors likely to follow.
That line says that the drive being used won't let MakeMKV bypass the region coding. As it says, errors will follow. There is a link that will let you see if there is updated, region-free firmware for your drive.
