I have problem ripping my copy of The Theory of Everything (2006) from Sony Pictures. It is region 4. The layout and design was in 2010.
It was able to retrieve the title structure, and it would rip till almost finish and then it fails at the end.
I've tried this on 1.8.0 on both linux (x64) and windows, both have the same result.
I'm not able to watch this in vlc, only watchable from Window's Media Centre.
Error ripping The Theory of Everything (2006)
molybtek
- makemkv_thetheoryofeverything.log
- (12.93 KiB) Downloaded 587 times
setarip_old
Re: Error ripping The Theory of Everything (2006)
Hi!
Have you carefully examined the original, commercial disc for physical damages (especially tiny nicks at the edges) and or dirt/oil, etc.?
molybtek
Yea, it looks clean to me. There's no marks scratches on it that I can see...
- Contact:
This is either a damaged disc, or a sophisticated copy protection. The only way to tell - please make and submit a test dump per instructions at /onlinehelp/testdump.html
molybtek
OK, I've made the test dump, and emailed to support. Thanks for your help.
https://docs.google.com/file/d/0B7Fxw2S ... sp=sharing
