The Waltons s02.d04
repstein
The Waltons s02.d04
Post by repstein » Sat Mar 09, 2013 6:30 am
Receiving an error when trying to rip title01 of The Waltons s02.d04 (s02.e10e11):
MakeMKV v1.8.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Randy/MakeMKV_log.txt
Opening files on harddrive at C:/DVDPrep/The.Waltons.s02.d04/VIDEO_TS
Calculated BUP offset for VTS #1 does not match one in IFO header.
Title #0 was added (14 cell(s), 2:28:24)
Title #1 was added (8 cell(s), 1:38:40)
Title #2 was added (6 cell(s), 0:49:44)
Title #3 has length of 12 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #4 has length of 12 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #5 has length of 21 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #5/1 has length of 11 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Title #5/2 was added (1 cell(s), 0:01:17)
Title #5/3 has length of 29 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Saving 1 titles into directory C:/DVDPrep
DEBUG: Code 11 at vW^!iGh9{?_'7^[\*nJ:121267063
DEBUG: Code 149 at vW^!iGh9{?_'7^[\*nJ:29398967
DEBUG: Code 3 at vW^!iGh9{?_'7^[\*nJ:121267109
DEBUG: Code 0 at e+!PDn"":im09l/RAaww*:213134584
Failed to save title 1 to file C:/DVDPrep/title01.mkv
0 titles saved, 1 failed
MakeMKV_log.txt
(797.46 KiB) Downloaded 611 times
setarip_old
Re: The Waltons s02.d04
Post by setarip_old » Sun Mar 10, 2013 9:38 pm
Hi!
Likely a physically damaged or dirty disc...
repstein
Post by repstein » Sun Mar 10, 2013 9:56 pm
setarip_old wrote:Hi!
Had no errors while copying the disc first with Clone DVD.
Randy
ToxicDreamz
The Waltons s02.d04
Post by ToxicDreamz » Mon Mar 11, 2013 9:57 pm
Randy
That doesn't mean the disk shouldn't be cleaned. You can also try setting the read retry count to 25 instead of the default 5 in the preferences.
