After ripping one blu-ray, pressing eject, and inserting another, I occasionally get the message LIBMKV_TRACE: UDF mount: disc not properly formatted(bad VDS) in v. 1.8.0 x64.
Closing and re-opening the program resolves the issue, and I can then click the picture of the drive to proceed with opening the disc.
judderod
Re: LIBMKV_TRACE: UDF mount: disc not properly formatted(bad
This is a bug in 1.8.0 . The exact reason is not known, if the best guess why it happens is right, then it will be fixed in 1.8.1 .
Please, if it happens again, close MakeMKV and save the full log file - MakeMKV_log.txt . This bug is truly random and so far we haven't seen a single log file.
judderod
Will do my best to get you a log.
judderod
Got it.
I had finished ripping Alien, pressed eject, and inserted Aliens.
DEBUG: Code 0 at B{3RiV; wF-#edzu=<OA:29394735
001003:0020 DEBUG: Code 0 at snfUJkYi%8M*dHy]ghss:121265315
001002:0020 LIBMKV_TRACE: UDF mount: disc not properly formatted(bad VDS)
Application exited at Thu Mar 07 14:43:22 2013
Let me know if you want the whole log.
judderod
And another. Aliens finished and ejected, Alien 3 in.
Application exited at Thu Mar 07 16:34:27 2013
captain
I got this error today too. log emailed
brown1480
Re: LIBMKV_TRACE: UDF mount: disc not properly formatted(bad VDS
Cliffhanger 4k
disk failure to open
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLAP2AB5550' at offset '65536'
udf: UDF mount: reading in reserve VDS extent
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLAP2AB5550' at offset '59434663936'
udf: UDF mount: error reading volume space
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLAP2AB5550' at offset '32768'
