last few times i have used makmkv the film has been way out and un watchable.
not sure where to start to find the problem?
Im running win7 with all my bd collection saved as full bd-iso, I mount the iso then open makmkv.
Liam
Lip sync issue
Re: Lip sync issue
Enable "Show AV sync messages" in Preferences->General. MakeMKV will print out all issues during conversion.
vanden
Re: Lip sync issue
Why not open the ISO file directly with MakeMKV ?liamgunslinger wrote: I mount the iso then open makmkv
What player (and filters) was used to play MKV obtained ?
liamgunslinger
Re: Lip sync issue
done, thanksmike admin wrote:Enable "Show AV sync messages" in Preferences->General. MakeMKV will print out all issues during conversion.
liamgunslinger
Re: Lip sync issue
i didnt know you could do it like that..vanden wrote:Why not open the ISO file directly with MakeMKV ?liamgunslinger wrote: I mount the iso then open makmkv
and using tmt5 from withing wmc running my movies
