Failure to load Watchmen
kalkwarf
Post by kalkwarf »
When I insert the Watchmen BluRay in the drive, MakeMKV works for awhile then ultimately fails. Log is below. I have converted other discs today, withthe same version of MakeMKV and the same drive. Any suggestions? Looking around the forum, it appears that other people have successfully converted this title.
MakeMKV v1.8.0 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5690H 4AH5" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00" opened in OS access mode.
Evaluation version, 26 day(s) out of 30 remaining
Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..00999FF8E61AC714DFEDEEA0EFB7741DBB0 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0BE2F5260DC2BBC9DD3F3FF9116FBCD7791 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..05FB4981FECA7B86AEF282187280131DDD2 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0BF155C03CB6BEDF8931CBC699004A059A5 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0A9A8A76579524AF82103E569208BBBA55F to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..04106897B7E82AFE72F06DAEDF407BCD3CC to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..098D488D2EE52E8E899DD0CB5C8E6C5DC74 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..027E637BC150F5B4FB0D45A9768662A27D3 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0A27DA4A4C39B07B504186D9CBBB04A64F5 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..08995C33AB9ABE55B8E7DACEF4D25D740C4 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..06288FA7E3E8F463AFC4C60989B0A433E3D to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..09935E09121D2447187A8F453D1AF43A7BF to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0FFB469C8811AAFA307735098822056AE04 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0D59C487694E7611D48D40C936900AEE848 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0EA513B6FDE80F53B8A0F7B00720413240E to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..009C9D1659C110A493EF09A195F5D7151C0 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0CFC9FB03DB5070BD0E0A1282BE6F7FAEE1 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0AF5B9176C304A1649159E6D8547BAD64EB to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..07F7ED089772EB8E6DFEA9C58F1AAF4B373 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..011CE32A92E600A17BDD587B8BA5C804866 to device 'OS:IOBDServices:4e2f8ba2f815f434:TSSTcorp BDDVDW SE-506BB TS00'
Highest AACS version is v12 , MKB saved as /Users/kalkwarf/.MakeMKV/MKB_v12_WATCHMEN.tgz
crowfax
Re: Failure to load Watchmen
Post by crowfax »
From your log:
I would do this and try again.
kalkwarf
Post by kalkwarf »
I tried the DASPI extension previously, and still had trouble.
I reinstalled it today to get the error messages, and this time it worked. I don't understand, but I'm happy enough with the result.
Thank you for the advice.
