MakeMKV 1.8 Signs won't rip.
marcusj0015
Post by marcusj0015 »
Starts reading and then gets stuck at 1.1KB I just paid Fifty fucking dollars, and it's not even god damn working, this is getting ridiculous.
There IS a CD in the blu-ray drive, but Signs is a blu-ray complete disc rip, sitting on the HDD.
Here is the log.
Debug log started at Sat Mar 02 01:29:46 2013 , written by MakeMKV v1.8.0 win(x64-release)
001005:0000 MakeMKV v1.8.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Marcus/MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at H1D6?(+&.PY0,5-F:121268995
001003:0020 DEBUG: Code 101016576 at -d9Xz8I-YwjLFLB`GJ:213132100
001003:0020 DEBUG: Code 101016576 at -d9Xz8I-YwjLFLB`GJ:29393930
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-RE HL-DT-ST BD-RE  BH10LS30 1.00' at offset '524288'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-RE HL-DT-ST BD-RE  BH10LS30 1.00' at offset '1048576'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading 'BD-RE HL-DT-ST BD-RE  BH10LS30 1.00' at offset '32768'
001003:0020 DEBUG: Code 0 at WZ^LxXb/!t?P%7?wlf6:29393424
003006:0000 Opening files on harddrive at E:/Downloads/SGN1JJD1
001003:0020 DEBUG: Code 0 at vSQ$@iER/`@'Fl:29393953
001003:0020 DEBUG: Code 0 at z)ln/(Zno[kV8hhV:29397748
003305:0000 AACS directory not present, assuming unencrypted disc
001003:0020 DEBUG: Code 0 at :j/n4]rJ?2`<lL]Up:121264671
001003:0020 DEBUG: Code 14 at z)ln/(Zno[kV8hhV:29403406
003025:0000 Title #00000.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00002.mpls was added as title #0
001003:0020 DEBUG: Code 0 at :j/n4]rJ?2`<lL]Up:213132100
003025:0000 Title #00016.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
tp=ZeNpjYBi6AAAAvAAB
001003:0020 DEBUG: Code 100 at lj^jzws<Rp!qx54Y.!:S:121265039
001003:0020 DEBUG: Code 0 at a@.8T')HOvTQ SNc}u*O:213129915
001003:0020 DEBUG: Code 0 at a@.8T')HOvTQ SNc}u*O:213130099
001003:0020 DEBUG: Code 0 at a@.8T')HOvTQ SNc}u*O:29393332
001003:0020 DEBUG: Code 0 at I)&#!{(+$yoa:Bp\ YQ:121262095
001003:0020 DEBUG: Code 0 at e+!PDn"":im09l/RAaww*:213134308
001003:0020 DEBUG: Code 0 at e+!PDn"":im09l/RAaww*:121266534
001003:0020 DEBUG: Code 0 at Z8VeO}d_^k99)gq'"::121261681
001003:0020 DEBUG: Code 0 at Z8VeO}d_^k99)gq'"::121262095
005043:0000 Failed to decode audio/video data for title #1 - invalid mux or internal error, title skipped.
001003:0020 DEBUG: Code 0 at Z=C{Vp"C&`fGblJ{:213131088
001003:0020 DEBUG: Code 0 at I-Vf'r&'3%ZHaLL:121268121
001003:0020 DEBUG: Code 0 at z)ln/(Zno[kV8hhV:29406373
003016:0000 Title #00028.mpls was skipped
003025:0000 Title #00030.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00032.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00033.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00040.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00041.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00054.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00055.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00068.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00008.m2ts was added as title #1
005043:0000 Failed to decode audio/video data for title #2 - invalid mux or internal error, title skipped.
003016:0000 Title #00009.m2ts was skipped
003025:0000 Title #00010.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003016:0000 Title #00013.m2ts was skipped
003016:0000 Title #00014.m2ts was skipped
003025:0000 Title #00015.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003016:0000 Title #00021.m2ts was skipped
003016:0000 Title #00027.m2ts was skipped
003016:0000 Title #00028.m2ts was skipped
003025:0000 Title #00030.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00033.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00038.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00039.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00044.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00045.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00046.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00047.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00048.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00049.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00052.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00053.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00054.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00055.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00056.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00057.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00058.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00059.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00060.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00061.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00062.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00066.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005015:0000 Saving 1 titles into directory E:/Movies/Signs using profile 'PERFECT' from file 'C:\Program Files (x86)\MakeMKV/perfect.mmcp.xml'
FFM001: Launching C:\Program Files (x86)\MakeMKV\mmffmpeg64.exe
FFM001: ffmpeg version 0.9.1.git Copyright (c) 2000-2012 the FFmpeg developers
FFM001: built on Feb 21 2013 06:40:54 with gcc 4.6.2
FFM001: libavutil      51. 34.100 / 51. 34.100
FFM001: libavcodec     53. 56.105 / 53. 56.105
FFM001: libavformat    53. 30.100 / 53. 30.100
FFM001: libavfilter     2. 59.100 /  2. 59.100
FFM001: libswscale      2.  1.100 /  2.  1.100
FFM001: libswresample   0.  6.100 /  0.  6.100
FFM001: [ffm @ 0000000000827540] resyncing
001003:0020 DEBUG: Code 0 at e+!PDn"":im09l/RAaww*:121265568
FFM001: [ffm @ 0000000000827540] Estimating duration from bitrate, this may be inaccurate
FFM001: Input #0, ffm, from 'tcp://127.0.0.1:63789?block&clean':
FFM001: Duration: N/A, start: 0.000000, bitrate: 72 kb/s
FFM001: Stream #0:0: Audio: pcm_s16le, 48000 Hz, 6 channels, s16, 4608 kb/s
FFM001: [flac @ 000000000070e1f0] No channel layout specified. The encoder will use Flac channel layout for 6 channels.
FFM001: Output #0, ffm, to 'tcp://127.0.0.1:63788?block&clean':
FFM001: Metadata:
FFM001: encoder         : Lavf53.30.100
FFM001: Stream #0:0: Audio: flac, 48000 Hz, 6 channels, s16, 128 kb/s
FFM001: Stream mapping:
FFM001: Stream #0:0 -> #0:0 (pcm_s16le -> flac)
FFM001: Press [q] to stop, [?] for help
Smithcraft
Re: MakeMKV 1.8 Signs won't rip.
Post by Smithcraft »
There sure is a lot of excitement in that log! Have you tried ripping it without using a custom profile, incase there is a problem with the profile?
SC
Post by mike admin »
marcusj0015 wrote:Starts reading and then gets stuck at 1.1KB I just paid Fifty fucking dollars, and it's not even god damn working, this is getting ridiculous.
Here is the log.
Physically damaged disc - /faq/item/7/catid/6
setarip_old
Post by setarip_old »
@marcusj0015
Hi!
Although you may be frustrated, your choice of language is unacceptable at this and many other forums. In addition to the fact that youngsters have access to this forum, there are also many mature people (myself included) who personally find such language offensive - and it certainly doesn't add anything of value to your post, especially in light of the fact that the problem you're having doesn't appear to have anything to do with MakeMKV...
marcusj0015
Here is the log.
But MakeNKV isn't even reading from the disc...
Smithcraft
Now I'm confused even more. If it isn't reading the disc, how is it getting stuck?
SC
marcusj0015
Smithcraft wrote:Now I'm confused even more. If it isn't reading the disc, how is it getting stuck?
SC
That's what I'm saying, the first part of the log (the SCSI part) is MakeMKV trying to read the Music CD in the drive, everything else is from the disc rip on the hdd, and I have NO IDEA what's going on.
ToxicDreamz
Post by ToxicDreamz »
There is something wrong with the disc, as Mike has stated. I've ripped Signs with no issues.
marcusj0015
ToxicDreamz wrote:There is something wrong with the disc, as Mike has stated. I've ripped Signs with no issues.
it ripped just fine once I deselected the LPCM audio, and eac3to converted it just fine, then on top of that, FLAC recompressed it fine too.
Smithcraft
And as I asked before, what about just ripping it without using a custom profile?
SC
marcusj0015
Smithcraft wrote:And as I asked before, what about just ripping it without using a custom profile?
SC
Yes, I've done that, it works fine, as I've stated before, but that isn't a permanent solution.
