Unencrypted Blu-Ray iso, why must makemkv fail?
rkofcal
#1 Post by rkofcal » Thu Feb 28, 2013 12:47 am
I have either a question or a feature request. If I have a Blu-Ray ISO image, which has the protection removed (let's say by AnyDVD), why can I not use makemkv to produce a .mkv? It simply resolves to failure because the volume ID or something is unknown. It seems fine when tried with dvdfab. Could we have an option to declare a source "unprotected"?
crowfax
Re: Unencrypted Blu-Ray iso, why must makemkv fail?
#2 Post by crowfax » Thu Feb 28, 2013 5:00 am
You can do what you're asking.
If it doesn't work turn on debug and post your log here.
paulster
#3 Post by paulster » Thu Feb 28, 2013 3:38 pm
That's how I rip 95% of my discs to MKV. It works fine for me, and I use the same tool to remove the protection and create the initial ISO for backup purposes.
rkofcal
#4 Post by rkofcal » Thu Feb 28, 2013 10:01 pm
Thanks for the confirmation that it can be done. I was getting consistent failures and updated to the latest version of makemkv (I am using the MAC OS version), and now it works. I have a few iso's that failed before and none of them fail anymore.
Strange that I had these issues earlier, maybe I had some corruption.
