Battlestar Galactica S2D1 (DVD)
chrissearle
Post by chrissearle »
Am having issues with this disk. Load the disk and ask makemkv to read the title list.
I get the following debug log (Note - I get that FAILURE: Code 0 prior to reading disk for every disk I use it on - they nearly all work so I've been ignoring that):
Debug log started at Sat Jan 16 13:05:01 2010 , written by MakeMKV v1.4.9 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.9 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/chris/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at fSxrS|A(s^T&@zxxNi2'W7V$14E:121264878
003010:000000:0000 Using direct disc access mode
003002:003011:0010 Calculated BUP offset does not match one in IFO header.
003017:000000:0000 Cells 7-end were skipped due to cell commands (structure protection?)
003036:000000:0000 Title #0 was added (6 cell(s), 0:41:49)
003036:000000:0000 Title #1 was added (6 cell(s), 0:41:41)
003036:000000:0000 Title #2 was added (6 cell(s), 0:41:55)
003036:000000:0000 Title #3 was added (6 cell(s), 0:41:55)
At this point the Opening DVD disc progress bar stops and the two estimated times start to increase. After a long while I get this:
001012:000000:0020 FAILURE: Code 2 at /uK@0& )_!8t-9b`gP:213139667
Not sure what code 2 is - is there an overview of what the different FAILURE: Code x numbers mean?
