I'm steadily backing up my blu-ray collection, but am also accumulating a pile of a few discs that just won't rip.
Here's a screen shot of what happens. I left this one overnight - see the Elapsed time.
This is ripping only the largest video stream and HD audio stream (be it HD-DTS, LPCM, True HD etc.)
Here's a paste of the last log:
Debug log started at Tue Feb 26 19:56:20 2013 , written by MakeMKV v1.8.0 win(x64-release)
001005:0000 MakeMKV v1.8.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\x/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=ddnqYViYCMq9j46GOcvrpFZmjwUCqtSFoutDiJralWKGDBsEl7CnGszufnpi47Xq6TWnfKXkIadN3AFEhR3o2WhcXN5oE2v1DcTbIWvFUQu4uRLDWJP1r2ZV5J5KQOBpcCnvM5K1HsloAHPIC8JWvX6NHGFHKk59aQ==
DCE=8zRHwnzKiUZyGQhxt1JqSmGm85BERQkKEevVdyHkrnyPJ4zZ9J4CT5c45MebNmNRFRugdiNJECfYcHJjEt0+iuT2jGebjOssn05ANZDymATKxT1m+0rJWlxc0KuzoMRMfeoXBfDd3/idFHOFNOC0t5Bbd3J/O4TAzQ==
DISCID=C4F2BA2B2F507AE0ABB3AEC811070A40EB0A5B17
003307:0000 File 00000.mpls was added as title #0
003307:0000 File 00005.mpls was added as title #1
003307:0000 File 00001.m2ts was added as title #2
003307:0000 File 00002.m2ts was added as title #3
003307:0000 File 00003.m2ts was added as title #4
003307:0000 File 00004.m2ts was added as title #5
003025:0000 Title #00008.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00012.m2ts was added as title #6
003307:0000 File 00013.m2ts was added as title #7
003307:0000 File 00014.m2ts was added as title #8
003307:0000 File 00015.m2ts was added as title #9
005015:0000 Saving 1 titles into directory E:/UNDERWORLD3 using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/flac.mmcp.xml'
005001:0308 File E:/UNDERWORLD3/title00.mkv already exist. Do you want to overwrite it?
FFM001: Launching C:\Program Files (x86)\MakeMKV\mmffmpeg64.exe
FFM001: ffmpeg version 0.9.1.git Copyright (c) 2000-2012 the FFmpeg developers
FFM001: built on Feb 21 2013 06:40:54 with gcc 4.6.2
FFM001: libavutil 51. 34.100 / 51. 34.100
FFM001: libavcodec 53. 56.105 / 53. 56.105
FFM001: libavformat 53. 30.100 / 53. 30.100
FFM001: libavfilter 2. 59.100 / 2. 59.100
FFM001: libswscale 2. 1.100 / 2. 1.100
FFM001: libswresample 0. 6.100 / 0. 6.100
FFM001: [ffm @ 000000000037d7c0] resyncing
FFM001: [ffm @ 000000000037d7c0] Estimating duration from bitrate, this may be inaccurate
FFM001: Input #0, ffm, from 'tcp://127.0.0.1:49453?block&clean':
FFM001: Duration: N/A, start: 0.000000, bitrate: 5346 kb/s
FFM001: Stream #0:0: Audio: truehd, 48000 Hz, 6 channels, s32, 5346 kb/s
FFM001: Output #0, ffm, to 'tcp://127.0.0.1:49452?block&clean':
FFM001: Metadata:
FFM001: encoder : Lavf53.30.100
FFM001: Stream #0:0: Audio: pcm_s24le, 48000 Hz, 6 channels, s32, 6912 kb/s
FFM001: Stream mapping:
FFM001: Stream #0:0 -> #0:0 (truehd -> pcm_s24le)
FFM001: Press [q] to stop, [?] for help
FFM002: Launching C:\Program Files (x86)\MakeMKV\mmffmpeg64.exe
FFM002: ffmpeg version 0.9.1.git Copyright (c) 2000-2012 the FFmpeg developers
FFM002: built on Feb 21 2013 06:40:54 with gcc 4.6.2
FFM002: libavutil 51. 34.100 / 51. 34.100
FFM002: libavcodec 53. 56.105 / 53. 56.105
FFM002: libavformat 53. 30.100 / 53. 30.100
FFM002: libavfilter 2. 59.100 / 2. 59.100
FFM002: libswscale 2. 1.100 / 2. 1.100
FFM002: libswresample 0. 6.100 / 0. 6.100
FFM002: [ffm @ 00000000007cd850] resyncing
FFM002: [ffm @ 00000000007cd850] Estimating duration from bitrate, this may be inaccurate
FFM002: Input #0, ffm, from 'tcp://127.0.0.1:49461?block&clean':
FFM002: Duration: N/A, start: 0.000000, bitrate: 108 kb/s
FFM002: Stream #0:0: Audio: pcm_s24le, 48000 Hz, 6 channels, s32, 6912 kb/s
FFM002: [flac @ 00000000006fdea0] No channel layout specified. The encoder will use Flac channel layout for 6 channels.
FFM002: Output #0, ffm, to 'tcp://127.0.0.1:49460?block&clean':
FFM002: Metadata:
FFM002: encoder : Lavf53.30.100
FFM002: Stream #0:0: Audio: flac, 48000 Hz, 6 channels, s32, 128 kb/s
FFM002: Stream mapping:
FFM002: Stream #0:0 -> #0:0 (pcm_s24le -> flac)
FFM002: Press [q] to stop, [?] for help
001003:0020 DEBUG: Code 1073751878 at G+89Ik<0teP(U.#s:29393861
001003:0020 DEBUG: Code 1073751878 at ;8Cgu;}qr_{:@u:`j:29395586
001003:0020 DEBUG: Code 4294967295 at zzU!@HDES0!CtQ/cAza:29394781
001003:0020 DEBUG: Code 0 at EQaH|Z=W!#QII1XE:213131732
001003:0020 DEBUG: Code 0 at EQaH|Z=W!#QII1XE:213132238
001003:0020 DEBUG: Code 0 at a@.8T')HOvTQ SNc}u*O:29393332
001003:0020 DEBUG: Code 20 at EQaH|Z=W!#QII1XE:121263337
If I hit the stop button, a confirm message comes up but clicking OK does nothing. The close button does nothing. The program can only be forcably ended in task manager.
Any help would be much appreciated
