MKV can't be opened because it's from an unidentified develo
Dan Viele
Post by Dan Viele »
The newest daspi_1.3.pkg and MKV can't be opened in Mountain Lion because security preferences allow installation of only apps from the Mac App Store and identified developers. There is a procedure to go around this... anyone able to describe it. Had to go back to MKV 1.7xx to use it.
Romansh
Re: MKV can't be opened because it's from an unidentified de
Post by Romansh »
Right-click, choose Open, confirm.
rlecomte
Post by rlecomte »
Login with admin privileges,
Go to System Preferences/Security and Privacy/General.
Where it says Allow applications downloaded from, choose "Anywhere".
ToxicDreamz
Post by ToxicDreamz »
System Preferences > Security > Allow apps from anywhere
It's a stupid Gatekeeper thing.
jeliker
Post by jeliker »
Romansh provided a solution below. Also, if you are launching from the Launchpad or from the Applications folder in your Dock you can CTRL-click an application you believe to be safe and it will run without requiring you disable Gatekeeper.
I present this alternative to labelling it stupid and shutting if off. Gatekeeper is a handy "filter" when used properly though some are easily overwhelmed by it.
