Aladdin Rip Failure (v.1.8)
KENSAI
Post by KENSAI »
Trying to determine if the errors below are from the slight scratches on the DVD, or from a software (1.8) failure to rip it.
MakeMKV v1.8.0 win(x64-release) started
Title #0 has length of 278 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #1 has length of 48 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #2 has length of 84 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #3 has length of 87 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #4 has length of 124 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #5 has length of 109 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #6 has length of 116 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #7 has length of 33 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #8 has length of 34 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #9 has length of 62 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Cells 10-end were skipped due to cell commands (structure protection?)
Title #10 was added (9 cell(s), 0:11:29)
Title #11 has length of 240 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #12 has length of 144 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #13 has length of 236 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #14 has length of 225 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Cells 9-end were skipped due to cell commands (structure protection?)
Title #15 was added (8 cell(s), 0:14:01)
Title #16 has length of 4 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #17 has length of 6 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #18 has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Cells 34-end were skipped due to cell commands (structure protection?)
Title #19 was added (33 cell(s), 1:30:03)
Title #20 was added (5 cell(s), 0:11:31)
Title #21 has length of 79 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #22 has length of 134 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #23 has length of 147 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #24 has length of 173 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #25 has length of 160 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #27 has length of 19 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #28 has length of 18 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #29 has length of 13 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #30 has length of 3 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #32 has length of 173 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #33 has length of 174 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #34 has length of 347 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #35 has length of 141 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #36 has length of 202 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #37 has length of 228 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #38 has length of 253 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #39 has length of 142 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #40 has length of 254 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #41 has length of 63 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #43/2 has length of 41 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #43/3 has length of 15 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/1 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/2 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/3 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/4 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #44/5 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #45 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #47 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #48 has length of 36 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #49 has length of 21 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #50 has length of 18 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/Jason Dunn_2/Desktop
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062245888, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062247936, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062249984, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062252032, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062254080, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062256128, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062258176, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062260224, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062262272, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062264320, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062266368, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062268416, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062270464, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062272512, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062274560, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062276608, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062278656, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062280704, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062282752, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2062735360, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276538368, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276540416, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276542464, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276544512, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276546560, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276548608, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276550656, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276552704, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276554752, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276556800, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276558848, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276560896, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276562944, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276564992, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276567040, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276569088, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276571136, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276573184, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276575232, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276577280, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276579328, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276581376, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276583424, attempting to work around
The source file '/VIDEO_TS/VTS_06_1.VOB' is corrupt or invalid at offset 2276585472, attempting to work around
Failed to save title 2 to file C:/Users/Jason Dunn_2/Desktop/title02.mkv
0 titles saved, 1 failed
crowfax
Re: Aladdin Rip Failure (v.1.8)
Post by crowfax »
Disc is damaged or dirty, clean it or swap it.
Additional suggestion - clean it and WAX it. I use Pledge furniture polish (or generic equivalent), because it both cleans the dirt off and fills in fine scratches. It won't do anything for major scratches, but it has a high success rate with getting disks "good enough" for ripping.
