Version 1.8.0 release notes
Romansh
Post by Romansh »
Can someone elaborate on what changes were done to result in "Improved compatibility of produced MKV files“?
Re: Version 1.8.0 release notes
Post by mike admin »
Only chapters - all chapters now have end times as well.
Romansh
Post by Romansh »
OK - thanks for the clarification.
Chetwood
Post by Chetwood »
What "Additional profile settings"? Are these all:
setFirstAudioTrackAsDefault="true"
setFirstSubtitleTrackAsDefault="true"
insertFirstChapter00IfMissing="true"?
setFirstSubtitleTrackAsDefault="false" will result in all sub streams ripped being set to "default = no", which is what I want?
Chetwood wrote:setFirstSubtitleTrackAsDefault="false" will result in all sub streams ripped being set to "default = no", which is what I want?
It should. By the way, this option was available for a while...
Chetwood
Post by Chetwood »
Right, but how do I achieve this?
bw001
Post by bw001 »
Chetwood wrote:Right, but how do I achieve this?
Change the default profile or create a new profile in your data directory.
You may also have to enable expert mode on the General tab in preferences.
I just started using this myself.
Chetwood
Post by Chetwood »
bw001 wrote:Change the default profile or create a new profile in your data directory. You may also have to enable expert mode on the General tab in preferences.
I have done both as you can see when you follow the link. I've also read up on conversion profiles but can't figure out how to make
- regular subs flagged to default = no (no matter if first sub stream or not)
- forced subs flagged to forced = yes and default = yes.
Would be nice to see Mike chime in on this as well as on how to get MakeMKV to not add a separate forced stream twice.
Chetwood wrote:- regular subs flagged to default = no (no matter if first sub stream or not)
Chetwood wrote:- forced subs flagged to forced = yes and default = yes.
Not possible, unless the forced track happens to be first (after order weight was applied). If thi is the case, then
ignoreForcedSubtitlesFlag="false"
Chetwood wrote:Would be nice to see Mike chime in on this as well as on how to get MakeMKV to not add a separate forced stream twice.
It's not possible. MakeMKV doesn't know that two separate tracks are identical until it finishes the conversion. And at that time it's too late - while it is easy to remove an empty track, removing a non-empty track requires overwriting all track data.
