I changed it now myself in the makefile, but it would be a great idea to install makemkv to /opt bei default, because most people prefer to keep /usr clean from all files not installed with a package manager and it makes it easier to uninstall it as well without hunting through all the directories ...
Steve
Install to /opt?
- Contact:
Re: Install to /opt?
Noted.
jabster
Steve, could you please tell me what you did to change the install directories? I did look in the make files, but could not figure out exactly what to change.steve wrote:Hi,
thanks,
john
