Firewall disc - Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE
setarip_old
Re: Firewall disc - Scsi error - MEDIUM ERROR:L-EC UNCORRECT
#16 Post by setarip_old » Wed Feb 13, 2013 7:08 pm
@ToxicDreamz
Let us know how it goes ;>}
ToxicDreamz
#17 Post by ToxicDreamz » Fri Feb 15, 2013 8:35 pm
I just exchanged both Blu-ray discs and both copied without issues. So it seems I just have bad luck and both previous movies were badly pressed or something. All is well. thumbsup.gif
setarip_old
#18 Post by setarip_old » Sat Feb 16, 2013 2:44 am
Glad to hear that simply swapping for replacement discs solved the problem.
Unfortunately, over the last year or so, this type of problem is becoming more and more prevalent. Hopefully, better QC will be performed throughout the industry...
ToxicDreamz
#19 Post by ToxicDreamz » Sat Feb 16, 2013 4:13 am
Yeah, it's a little upsetting. :/
Jeebs
#20 Post by Jeebs » Thu Feb 21, 2013 1:40 pm
I have seen this error for functional disks. I have a BT20N by LG that errors out on 10-15% of my Blu Rays. I can take the exact same disk over to a Samsung SE-506AB drive and it will work fine. The only thing that I can think of is that there is some hardware within the drive that prevents our process. Of course, I am open to other ideas :). When this happens, I cannot even take an ISO of the disk (using dd in Linux... doesn't get more basic than that...)
I have tried multiple different setups including passing the drive through a VMware ESXi, direct connecting to the computer, Linux and Windows OS's. The BT20N consistently causes issues. Every disk that breaks with the LG BT20N works fine with the Samsung SE-506AB.
What type of drive are you using?
setarip_old
#21 Post by setarip_old » Fri Feb 22, 2013 1:25 am
@Jeebs
Hi!
Retire your LG. No point in looking for trouble...
Jeebs
#22 Post by Jeebs » Fri Feb 22, 2013 2:14 am
setarip_old wrote:@Jeebs
Hi!
Indeed. I have come to terms with the waste of cash and troubleshooting time. Leaving it with this: @lgelectronics #fail
I am actively trying to find my own (not borrowed) Samsung drive, but the 506AB are end of life. (I have post under general topics, not trying to hijack :D )
