rippa
#1
Post
by rippa » Thu Feb 21, 2013 9:47 pm
Why is the new version so much bigger in file size?
1.7.10 was around 3 MB and 1.8.0 is now 23 MB!?
Are the new icons that big or is there any other reason?
#2
Post
by mike admin » Fri Feb 22, 2013 7:49 am
The compressed setup its only slightly bigger. The executable is bigger as it now uses uncompressed icons while the old one had icons compressed that were was uncompressing in memory.
It sounds unnatural, but having a big executable is better from performance point of view - less memory is used.
rippa
#3
Post
by rippa » Fri Feb 22, 2013 11:10 am
Thanks for the quick answer!
Chetwood
#4
Post
by Chetwood » Fri Feb 22, 2013 4:48 pm
It would be very helpful to have the history.html installed with MakeMKV. Also, why go with rtf rather than pdf for license and readme?
