I am new to this forum and this piece of software.
With my Sony Handycam (Tapes) I have made dvd files (Video_TS and Adio_TS).
When I convert with MakeMKV, will there be any loss of quality?
What I have is not all the best, but when I convert I hope it will not get any worse.
Is it a 1:1 conversion?
I hope you can inform me about this?
Home Video Quality Loss?
Re: Home Video Quality Loss?
MakeMKV simply repackages what is there - the contents are unchanged (other than decrypting if encrypted), by default.
There are some audio formats that CAN be changed, but that is optional.
Raymonddeniet
Ok, thanks. I will try one dvd tonight.
Raymonddeniet
I tried to convert my home video's to mkv.
The first 2 discs worked.
But when I tried the 3rd, 4th or 15th for that matter I got a kind of error.
It asks for a disk. The first 2 times it didn't.
See enclosed file.
Does anybody know this issue?
See enclosed file.
Check the link in my signature for how to turn on debugging; it will give a lot more information about why something failed.
Wild guess - the disk has a defect in it that caused the system to give up trying to decode it. Cleaning helps a lot with "well used" disks, when the family isn't too particular about what they scrape the disk over when they're loading/unloading the player. That's WHY I put things on the media server, so I don't have to fight about it!
Chetwood
FYI, there's no need for posting a screenshot (better use png next time), you can copy and paste all text from the log window pane.
Raymonddeniet
Well, its not a physical disc but i want to make a mkv from dvd folders from my harddrive.
My first transfers from the harddrive worked. Then later i got this problem.
Ok, tnx. I will use png next time
