Unable to open Atlas Shrugged part two
johnnyreb
Post by johnnyreb »
I get error code:
MakeMKV v1.7.10 win(x64-release) started
Loaded 185 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as D:\Video/dump_Atlas_Shrugged_2_3A4F4027CA484113.tgz
Failed to process BD+ code, please check /svq/ for updated program and SVQ files
Re: Unable to open Atlas Shrugged part two
The output told you what you need to do.
Find the file D:\Video/dump_Atlas_Shrugged_2_3A4F4027CA484113.tgz
Follow the instructions at www.makemkv.com/svq/
This is a second reply, because the first reply is awaiting moderation due to the inclusion of a link.
In your message, you quote the output of MakeMKV. It gives you the location of a file that needs to be sent to Mike, and a link to where to find instructions on how to do that. That link is active in your message, displayed as "/svq/". Click it, and follow the instructions.
johnnyreb
Post by johnnyreb »
Sorry I just glossed over the directions. Now the problem is dump file size is 36 meg and my email limit is 25. Do I need the complete file or break it down into a couple of emails?
If you can upload the file to a web-accessible location (there are services that allow you to post files for free, I just use one of my personal web servers), you can send Mike a link to the file at the email address in the instructions.
johnnyreb
Post by johnnyreb »
Thanks for great idea, but couldn't find free host that would let me upload file that large. Got it broke down to two emails and sent to Mike
Romansh
Post by Romansh »
For the future: Dropbox, SkyDrive, iCloud etc.
johnnyreb
Post by johnnyreb »
Thanks, got dropbox. Worked painlessly, and sent email link to mike.
