Unable to open blu-ray disk, is this due to expiration of program use, if so, don't understand, upon initial activation of make mkv was stated that free function was available while in beta config. Please advise, jimmymae
MakeMKV v1.7.10 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\jimmy/MakeMKV_log.txt
Evaluation period has expired, shareware functionality unavailable.
DEBUG: Code 0 at #2%nH]m+8/Nq5! Y:29395402
DEBUG: Code 0 at #2%nH]m+8/Nq5! Y:29396897
DEBUG: Code 233 at e7smudgtjRP8WTFdtSWPN6OW:0
DEBUG: Code 233 at G+slfw9mIx6O3L2UucIBxBSN:0
unable to open disk
Smithcraft
Re: unable to open disk
It's not freeware, it's a paid application. It's free for 30 days.
If you wish to continue to use it, you can either buy it, or use the updated beta registration key.
SC
SC
avr62
Today downloaded and ustvnovil version 1.8 beta. When loading BluRay drive program reported: MakeMKV v1.8.0 win(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Opening files on harddrive at C:/Video/Home (2009) BD
AACS directory not present, assuming unencrypted disc
- Contact:
avr62
Nothing is impossible ... (
- Nothing is impossible ... (
- ERROR.jpg (129.28 KiB) Viewed 15045 times
- Code is incorrect.jpg (112.81 KiB) Viewed 15045 times
ToxicDreamz
Well you found a grammar error at least. 0_oavr62 wrote:Nothing is impossible ... (
