Taken 2 US not working
ez4nick
Post by ez4nick »
The disc plays fine in a Blu-Ray play but on my computer and in mkv it does not want to cooperate.
Error log looks like this:
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '147456'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '215040'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '61440'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '36864'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '24576'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00050.m2ts' at offset '178176'
Also when it is trying the drive on my pc makes weird clicking noises..
Is this a problem with the disc or my pc?
setarip_old
Re: Taken 2 US not working
Post by setarip_old »
Hi!
As has been noted here and elsewhere MANY times over the years, standalone players are more "forgiving" than are computers and software players.
Try carefully cleaning the disc and you PC burner/reader...
ez4nick
Post by ez4nick »
I tried cleaning the disc many times and even before I tried using it the disc looked nearly perfect to me maybe 1 fingerprint on it. Still no luck after cleaning many times and re-trying. I can't see any scratches on the disc either.
crowfax
Post by crowfax »
Just because you can't see any marks doesn't mean the disc isn't damaged.
There is no copy protection on blu-ray that causes read errors. You have read errors. Either the disc is bad, or the drive is bad.
ez4nick
Post by ez4nick »
The drive can play anything but this disc, so then the disc must be bad.
setarip_old
Have you tried running a cleaning disc on your reader/burner? Maxell makes one that sells for about $10US...
exploding_mo
Post by exploding_mo »
I have the US version. I'm seeing these errors:
MakeMKV v1.7.71 darwin(x86-release) started
Optical drive "DVD+R-DL LITE-ON DVDRW LH-20A1L BL06" opened in DASPI v1.3 mode.
Optical drive "BD-ROM ASUS SBC-06D1S-U A201" opened in DASPI v1.3 mode.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FC6ABDA522C483ADB72C05586D4784F1AC to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07502D075C61E582BD4EED46CE6E65FABC3 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C4BCCBA8503A0AC05C8AF5DF3E80784E59 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04717788197227ECEA9EFFDB7E98AA44C71 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0DD71975A51B487C1A17002B52411D95B05 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07F26A5D53FE88E2991855C5BD0CE5DA16E to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0678A3F0FA8E6F721BA75C95E16B1FABFDE to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07CC597F6CC42BB4C11E6755FDD7EDECA6E to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..052509B7F2EF028795EDC5AAC1877223551 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06C2344332691C5BA9DF0A04FFFA0855439 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0743CD04F0D01B4A45C828F783E6B87C26D to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06D6AEAD25E34A5B90243495445C2B31B4D to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EDE875D31815CCEBFA4E897EF2D0D386EC to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02E437733570964B23A486D99F838D0BE6F to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CF9DB1D4129E92AAD0C92B7D59B37D1D69 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F2FFBB42F622B4CF8B415B6129BDA6B6AC to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07E069738454A80DCF17BB6008EC84D3601 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06A1669AE967F60ADC6E0C560617F835C51 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01BA99D2B7790C6A44D8E5E7C6E8564D88A to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0803ACBACBB0CECC1FBD6FE1EEC4CE5F084 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..061F97DE57626DCF383925DA95181E88386 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0492E6F59E21E078CB043F9586AA1097663 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FF51072E7531FF2A91CEA9F1407961E54B to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03850146EC73F445C493547F443E6F5444E to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B46839B5DE1A5555D1184377447D744E60 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FBFD6B3E0DC3A04F6C8144CFC247F64FA1 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AF971D9835DC9B05DDC6A2340AC5FA2B8A to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F7FF011810E314969362728F8A6E95E07F to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AEE6CA38CA13BD92D6F114311E24B2E8B7 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..063D6BCB7CC966A682D4BD995CFF4B0755A to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Backing up disc into folder "/Users/christianlair/Movies/backup/Taken 2"
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E578C2B16073E4BBFEE639C9E9FBD6A78A to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0688F4ADB410AF552F32BB72F183528A7C4 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03AB42FA9D1BCE63E8D62778732B1B43A67 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D4C70F0ED5B31CDF197462848AE22DC388 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BEEAA01FAEEEE92FDCF0A96096FBE88C0F to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03D9864D6E96AB7D72802055A189A160B99 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05AE9F727F2370F363CFDA3F4E58F5CD392 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0372B2A1FC9F5213EB6FB2BE96CF35BC763 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FBF3C93F6A33EE7A2E2B5228845389329C to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09981D0C3758832E8DBF52AFF70A9CC6527 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..028892997DD81B7E376D4BC63ED62B6CA3C to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B0358655A8F683560042F56E07328D1923 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..020FADAC9616232A9BA00D10F8DC55C219C to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0464F79A455C4D43C8E4FE9360961879850 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B31CCFDC1048BE47A4F31DD4D234AB121F to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0660721BA817C9CC26F3D13C1309A7785DB to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..042EA1C660D043C7BE85A74A355225EE125 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C4B592ADF2B7AA0C88012AB90BB8BB1A95 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..023C7E60699C765B89796C25ADA2503E2A9 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..016D2A0BAF30CB99387EC8CBEF88D430A7E to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04D74581A750A4C37CBAD645FC6D465A666 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01DD2A2945E20277652BBA92BA16990DC26 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AC960485888D5CCB597BFDFF447B3CEB5E to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A45DCF7138D885576E738DCF17EAA1C20A to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..051B7FE819C08E3417AB9D11E836C94F8DF to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04EBF215E0AE96C2C70F4977F6BE4FEF68E to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A2E0F335731BBA74CACF9D71399EA315D5 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08D3EE90C7258C0DC5499705B40C11FDEA2 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..075D20B5868605FC488AB01616FC08C9F10 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07D2A9932EAF276E70A37010211DBB68AE2 to device 'DASPI:IODASPIService:8e82e56bfa37ca8e:'
Backup failed
crowfax
Post by crowfax »
exploding_mo wrote:I have the US version. I'm seeing these errors
Upgrade to 1.7.10
