Input/output error on The Pirates! Band of Misfits
DakotaPaul
#1 Post by DakotaPaul » Mon Feb 18, 2013 12:47 am
I think this is the first error I've seen after ripping many of my Blu-rays. What's causing this?
Full log: http://pastebin.com/buLahi4P
MakeMKV v1.7.71 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/PZ/MakeMKV_log.txt
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHB" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
Optical drive "BD-ROM HL-DT-ST BDDVDRW UH08LS10 1.00" opened in OS access mode.
Error 'Posix error - Input/output error' occurred while issuing SCSI command A30..00200740100720..0736F9AF056F5625F2009D65A8472B0D37A to device 'OS:IOBDServices:63ad7cd554e137cc:HL-DT-ST BDDVDRW UH08LS10 1.00'
DEBUG: Code 0 at [3A_y5<ArF\G0>z=1:213130743
DEBUG: Code 0 at t|b1YhhpE($sO%+Y3b:29395034
DEBUG: Code 0 at t|b1YhhpE($sO%+Y3b:121262394
Error 'OS error - posix:00404040' occurred while issuing SCSI command AD010..080002400 to device 'OS:IOBDServices:63ad7cd554e137cc:HL-DT-ST BDDVDRW UH08LS10 1.00'
DEBUG: Code 0 at t|b1YhhpE($sO%+Y3b:121264234
DEBUG: Code 4 at t|b1YhhpE($sO%+Y3b:121262394
DEBUG: Code 0 at %1d-w7ehgQ{ v+;*:121263544
DEBUG: Code 0 at %1d-w7ehgQ{ v+;*:29396897
Re: Input/output error on The Pirates! Band of Misfits
#2 Post by mike admin » Mon Feb 18, 2013 10:35 am
DakotaPaul wrote:I think this is the first error I've seen after ripping many of my Blu-rays. What's causing this?
Your drive reflashed itself when you've inserted a new disc, and you're using an old version of MakeMKV. Just update to the latest version - 1.7.10
DakotaPaul
#3 Post by DakotaPaul » Mon Feb 18, 2013 5:48 pm
Arg! I'm an idiot. :oops: Updated to 1.7.10 and it works. Thanks for the reply.
