MakeMKV slows down during ripping till it "dies" ?
Vilago
Re: MakeMKV slows down during ripping till it "dies" ?
Post by Vilago »
I also have this issue. Also using an LG external, but on the mac. Maybe this is related to drive speed? I know the macs aren't exactly known for drive speed so maybe this is it...
HolgiB
Post by HolgiB »
Interesting....thanks for posting !
You could try the following:
Use a different software for ripping the BDs on your mac.
If you can confirm similar behaviour (MakeMKV "dies" but Blu-Ray ripper works) then we have at least some sort of confirmation that not neccessarily the BD or BD-drive are corrupt. :mrgreen:
I still doubt that any of the BDs or my drive are corrupt in any way.
Post by mike admin »
You don't need to use any special software to verify - blu-ray discs are always readable. Just try copying all files from the disc in finder. If it fails - you have a hardware problem.
HolgiB
Post by HolgiB »
Mike, I do not feel like argueing with you....you are the expert in this field.
I did just share my observations as End-user.
I have one BD behaving strange with MakeMKV which really had issues (Predator Hunter Edition). When ripping this huge set of BDs for a friend I experienced such issues several times (MakeMKV "died" while Bluray Ripper from DVDFab could rip) that I can hardly believe all those BDs had any sort of defect. I also doubt that my BD drive has a defect because it still works fine with the majority of BDs / DVDs I am ripping.
Even if people tell me to clean the BDs, tell me that either the BDs or my BD drive are corrupt, I find this hard to believe.
Even more when some kind of pattern shows up (Software A rips while software B dies). May be DVDFabs Stuff uses different approaches to read / access the BDs ? I dunno....
I would like to see Vilago's results.
@Vilago: OK, do a double cross-check.
Try to copy the encrypted files from the specific BD to your HDD and try as well to rip it with BDCopier for the Mac from DVDFab.
atomic7431
Post by atomic7431 »
ok just trying to do snow white and the huntsman bluray and after a short while im getting 0.0x speed also -
MakeMKV v1.7.10 win(x64-release) started
Title #00013.mpls has length of 118 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00000.mpls has length of 118 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00020.mpls has length of 79 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
Title #00307.mpls(3) has length of 38 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00308.mpls has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00308.mpls(2) has length of 32 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00308.mpls(4) has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00308.mpls(6) has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00308.mpls(8) has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00308.mpls(10) has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00309.mpls has length of 27 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00309.mpls(2) has length of 32 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00309.mpls(4) has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00309.mpls(6) has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00309.mpls(8) has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00310.mpls has length of 30 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00310.mpls(2) has length of 32 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00310.mpls(4) has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00310.mpls(6) has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00310.mpls(8) has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00310.mpls(10) has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00311.mpls has length of 47 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00311.mpls(2) has length of 32 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00311.mpls(4) has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00311.mpls(6) has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00311.mpls(8) has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00311.mpls(10) has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00312.mpls has length of 29 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00312.mpls(2) has length of 32 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00312.mpls(4) has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00312.mpls(6) has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00312.mpls(8) has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00312.mpls(10) has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title 00802.mpls is equal to title 00800.mpls and was skipped
Title 00803.mpls is equal to title 00801.mpls and was skipped
Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00015.m2ts has length of 25 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00016.m2ts has length of 59 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00017.m2ts has length of 59 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00020.m2ts has length of 59 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00021.m2ts has length of 42 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00022.m2ts has length of 36 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00098.m2ts has length of 70 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00107.m2ts was added as title #2
File 00108.m2ts was added as title #3
Title #00109.m2ts has length of 55 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00110.m2ts was added as title #4
File 00111.m2ts was added as title #5
Title #00112.m2ts has length of 258 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00113.m2ts has length of 107 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00114.m2ts has length of 82 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00115.m2ts has length of 125 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00116.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00117.m2ts has length of 187 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00118.m2ts has length of 32 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00119.m2ts has length of 52 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00120.m2ts has length of 41 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00122.m2ts has length of 1 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00123.m2ts has length of 61 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00124.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00125.m2ts has length of 31 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00126.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00127.m2ts has length of 6 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00128.m2ts has length of 1 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00129.m2ts has length of 42 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00130.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00131.m2ts has length of 31 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00132.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00133.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00134.m2ts has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00135.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00136.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00137.m2ts has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00138.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00139.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00140.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00141.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00142.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00143.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00144.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00145.m2ts has length of 1 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00146.m2ts has length of 26 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00147.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00148.m2ts has length of 31 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00149.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00150.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00151.m2ts has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00152.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00153.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00154.m2ts has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00155.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00156.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00157.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00158.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00159.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00160.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00161.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00162.m2ts has length of 1 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00163.m2ts has length of 29 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00164.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00165.m2ts has length of 31 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00166.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00167.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00168.m2ts has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00169.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00170.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00171.m2ts has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00172.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00173.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00174.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00175.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00176.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00177.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00178.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00179.m2ts has length of 1 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00180.m2ts has length of 46 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00181.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00182.m2ts has length of 31 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00183.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00184.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00185.m2ts has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00186.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00187.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00188.m2ts has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00189.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00190.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00191.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00192.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00193.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00194.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00195.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00196.m2ts has length of 1 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00197.m2ts has length of 28 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00198.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00199.m2ts has length of 31 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00200.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00201.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00202.m2ts has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00203.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00204.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00205.m2ts has length of 40 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00206.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00207.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00208.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00209.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00210.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00211.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00212.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00213.m2ts has length of 47 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00214.m2ts has length of 45 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00215.m2ts has length of 137 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00216.m2ts has length of 12 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00217.m2ts has length of 79 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00218.m2ts has length of 47 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00219.m2ts has length of 91 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00220.m2ts has length of 29 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00221.m2ts has length of 64 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00222.m2ts has length of 28 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00223.m2ts has length of 68 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00224.m2ts has length of 32 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00225.m2ts has length of 121 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00226.m2ts has length of 168 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00227.m2ts has length of 43 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00228.m2ts has length of 105 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00229.m2ts has length of 85 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00230.m2ts has length of 24 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00238.m2ts has length of 148 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00300.m2ts was added as title #6
File 00301.m2ts was added as title #7
File 00302.m2ts was added as title #8
File 00303.m2ts was added as title #9
File 00304.m2ts was added as title #10
File 00305.m2ts was added as title #11
File 00306.m2ts was added as title #12
Saving 1 titles into directory D:/Adult HD Movies/Snow White and the Huntsman I (2012) [tt1735898]
not stopped yet but will see what happens, ive never experienced this before today.
HolgiB
Post by HolgiB »
atomic7431,
it would be interesting what happens when you try to copy the encrypted files from the BD over to your PC or may be simply generate an ISO from the BD ?
atomic7431
ok quick and odd reply, i noticed my mkvs were changed to autoplay back using acestream otherwise known as torrentstream, i changed this back to vlc player and the speed increased to a normal 4.4x, so i then changed it back to ace stream and voila 0.0x changed back to vlc and the speed increased again! must be torrent stream trying to access the file for streaming even though i havent told it too and so causing slow down in ripping speeds. hope this helps some :)
HolgiB
Post by HolgiB »
So I other words you do not have the issues I described about ripping BD to MKV without any additional programm accessing the drive ? :roll:
atomic7431
it wasnt accessing the drive but the file being created. ie the default program used to play back that file type had been altered so i changed it back and all was then well.
The bluray now finished ripping without fault after changing the default file playback (right click on the file, open with - chose default program - picked vlc again)
Lucille
Post by Lucille »
Hi HolgiB,
I'm having the exact same problem as you and i can't find much on this issue except your post.
Did you ever find out what was the issue?
i have had it happen to me a few times and i don't know what is the issue, the disc rips well until a point where it just slows to a grind and eventually the process fails. I had a BD with 4 titles, 2 were ripped without a problem, 2 had this issue... it's quite maddening.
HolgiB
Post by HolgiB »
Hey there,
haven't ripped a BD since ages but I guess times are changing... :mrgreen:
I found out what the issue was somewhat the hard way. My external BD drive simply was slowly dying.
The named BD in this thread was simply the first one where the drives started to cause irregular issues while ripping.
IIRC the drive somewhat worked until I trashed it but someday even playing back unencrypted video files didn't function on a regular basis.
Hope your drive isn't dying as well....
