Error while converting blu-ray to .mkv
Smithwess
#1 Post by Smithwess » Sun Feb 17, 2013 7:10 pm
Hi all,
at always I get an error 'Posix error - Input/output error' occurred while writing data to '/Volumes/Qdownload/title00.mkv' at offset '123456789' while converting blu-ray structured disk to .mkv file. Uses last v1.7.10 of MakeMKV software for Mac OS X. Source blu-ray files are on the remote catalog of linux server and destination catalog for .mkv files on same server too. Otherwise no errors occured if I change the destination to local OS X directory, for example. This is good but uncomfortable since it presupposes an extra copy operation. I use the smb net protocol across all network.
Thanks, Vadim.
Re: Error while converting blu-ray to .mkv
#2 Post by Woodstock » Sun Feb 17, 2013 10:47 pm
The issue is likely the SMB networking - there are a lot of circumstances where an SMB share will be viewed as having a 4GB limit on file size, even if such a limit does not actually exist. Some versions of OS/X limit this to 2GB, due to a bug. The operating system will prevent writing beyond that point, even if there is plenty of space.
Sometimes this is "cured" by mapping the drive as a resource on the local machine, as opposed to using a network URLs, but it appears that you have already done that.
Can you COPY one of the result files from the local drive to the network drive successfully?
Smithwess
#3 Post by Smithwess » Mon Feb 18, 2013 5:05 am
Woodstock, thank you.
It seems to me smb networking is the real reason of this issue too. But why I haven't this error on MakeMKV running under Windows 7 or 8 instead Mountain Lion? I venture to suggest that the implementation of the smb protocol on Windows is some different.
Yes, I can successfully copy various collection of files of any length from a local both OS X and Windows machines to the remote Linux server directory.
crowfax
#4 Post by crowfax » Mon Feb 18, 2013 6:07 pm
Smithwess wrote:I venture to suggest that the implementation of the smb protocol on Windows is some different.
Microsoft have altered SMB a lot for Windows, everyone else uses the standards laid out in the original plans, then reverse engineers the changes Microsoft have made.
The Wikipedia page for SMB is very interesting if you're in the mood for a history lesson.
Smithwess
#5 Post by Smithwess » Mon Feb 18, 2013 6:46 pm
crowfax, thank you
I'll try though it will not be easy, I'm not a professional IT..
Smithwess
#6 Post by Smithwess » Sun Feb 24, 2013 1:46 am
Hi guys,
Due to Appletalk protocol switched on server side and using client AFP share has helped to solve this issue. No errors occurred when I used this method.
