The [URL] tag enables auto-moderation, even if url points to this site. This will be fixed eventually. In-line links to this site do not enable auto-moderation.Chetwood wrote:Beats me, why I was moderated, there were no swear words and I even forgot I was in the moderation queue so I posted something similar again. Oh well.Ghostm wrote:any time i tried to quote you, it seemed to be pending moderator approval and i have no idea why it was not posted.
Forced subtitle label
- Contact:
Re: Forced subtitle label
Any way this could be made dependent on the post count as well?mike admin wrote:The [URL] tag enables auto-moderation, even if url points to this site. This will be fixed eventually. In-line links to this site do not enable auto-moderation.
nevcairiel
Actually, not really, as long as the player does what the MKV spec tells it to do in this case, and otherwise has a smart stream selection.Chetwood wrote:Which would require additional logic for people like me who always rip both English and German tracks. So if I were to watch Avatar in english with english subs, having two forced tracks automatically flagged as forced might cause problems.
Here is an excerpt from the MKV Spec regarding the "forced" flag:
Right now i manually flag the appropriate sub streams as forced to get players to behave properly, but automation would be nice, even if its only possible in a custom profile.There can be many forced track for a kind (audio, video or subs), the player should select the one which language matches the user preference or the default + forced track.
Has the track name template feature been added to conversion profiles yet? If so, how are they used? I can't see where the option would be in the original post on the conversion profile XML schema.mike admin wrote: Wed Feb 13, 2013 7:47 amThis is a great suggestion. Track name templates will be the next feature for conversion profiles.Chetwood wrote:So how about adding placeholders to the conversion profiles for subs (and audio)paulster wrote:but it would be a whole lot more useful and less time-consuming than it is currently to name the tracks.
%L: language
%F: encoding format
which results in "German/VobSub" or "English/Lossless" or something?
I don't think it has but you could try and see for yourself. Enable 'expert' mode under preferences and then the output filename template is on the advance tab.
Not exactly sure what you mean, but the below will add "Forced" to the track names of tracks flagged as forced. I assume if they're not flagged or tagged in some manner then MakeMKV cannot determine it at which you'd always have to manually go through them.nevcairiel wrote: Fri Feb 22, 2013 10:08 pm Right now i manually flag the appropriate sub streams as forced ...
#!/usr/bin/env python3
# Usage: ./scriptname.py3 filename.mkv (0 error checking, requires "mkvmerge" and "mkvpropedit")
import subprocess, sys, json, re
tracks = json.loads(subprocess.run(["mkvmerge", "-J", sys.argv[1:][0]], capture_output = True, text = True).stdout)["tracks"]
for t in tracks:
if t["properties"]["forced_track"]:
track_name = "Forced"
if "track_name" in t["properties"]:
if re.search("(?iu)^forced", t["properties"]["track_name"]):
continue
track_name = "Forced: " + t["properties"]["track_name"]
subprocess.run(["mkvpropedit", sys.argv[1:][0], "--edit", "track:" + str(t["id"]+1), "--set", "name=" + track_name ])
