I have a new BD, Secret of Moonacre (nordic version), that MakeMKV only finds 2 out of 4 subtitles.
Please see the picture. At the snapshot used AnyDVD image to be able to show comparision with BDREbuilder.
Same behaviour when I disable anydvd and use the original disc. eac3to also finds all subs.
See the picture that Swedish and Finnish is missing when MakeMKV has processed the disc.
More then happy to supply *.CLPI and *.MPLS if needed.
MakeMKV bug in finding subtitles on specific BD
Re: MakeMKV bug in finding subtitles on specific BD
I only just downloaded the latest version of MakeMKV yesterday, and I'm having the exact same issue as well, with many subtitles missing when I open a few blu ray discs using MakeMKV.
Can anyone help overcome this issue?
- Contact:
yes please, to support@makemkv.com . Please check that you do see subtitles on the player, and not just in BD rebuilder. Also please provide the contents of lower log window, at least lines "File xxx was added as title yyy"ds2249 wrote:More then happy to supply *.CLPI and *.MPLS if needed.
Submitted the logfile and MPLS/CLPI files as requested. If there is anything else you need don't hesitate to ask.mike admin wrote:yes please, to support@makemkv.com . Please check that you do see subtitles on the player, and not just in BD rebuilder. Also please provide the contents of lower log window, at least lines "File xxx was added as title yyy"ds2249 wrote:More then happy to supply *.CLPI and *.MPLS if needed.
- Contact:
Thank you very much for submitting files - the error is found and will be corrected in a next version.
I can confirm that v.12 works as it should in this case. Thanks for the update!mike admin wrote:Thank you very much for submitting files - the error is found and will be corrected in a next version.
