Failed to save title to file revisited
PeacePipe
Post by PeacePipe »
First failure of any kind I've ever experienced. (Using MakeMKV for 2-3 years.)
Failed to save "A Chinese Ghost Story 2". Standard DVD (Megastar Video Distribution (HK) LTD". Everything runs as normal, but at the end of the "Make MKV" event popup error report says: "Copy complete, 0 files saved, 1 failed".
DVD is in good shape, clean. Can be played with PowerDVD 8 in the same computer, same drive, and could also be saved with AnyDVD as an ISO file. The ISO too plays fine, complete with English subtitles.
DrWatson was ran but produced no debug file. Attaching 3 screenshots of MakeMKV process.
Best regards
MakeMKV runs and fails.jpg (85.62 KiB) Viewed 32808 times
Options select.jpg (74.87 KiB) Viewed 32808 times
Scan results.jpg (63.19 KiB) Viewed 32808 times
ToxicDreamz
Re: Failed to save title to file revisited
Post by ToxicDreamz »
This may sound stupid, but try saving it to a different location.
PeacePipe
Post by PeacePipe »
Nothing is too wild at this point. I've even tried to save it under another name and not by the default "UNDEFINED", or letting to include ALL options, (Chinese, Thai, etc. subtitles.), AND setting the file size filter to 10sec instead of my normal 600sec (5min) value.
But! Different source (DVD reader) device, different target (hard drive), different folder and different name. But exactly the same results! As always MakeMKV properly detects all the components and file size: 3973.2M, but terminates the process in less than 1 second with the popup error, displayed in the sample screenshot.
(I forgot to mention in my original post, that when attempted to "MakeMKV" the perfectly functional ISO file created by AnyDVD, that process was also terminated with the exact same error.
Try turning on debugging (see my signature for how) and try again; debugging will give more details on why it failed.
setarip_old
Post by setarip_old »
Probably irrelevant here, but 600 seconds is equal to 10 minutes, not five...
gizmogeek
Post by gizmogeek »
I have had a similar problem with several of my discs. AnyDVD rips them without errors. CloneDVD2 can rip the problem titles to a new DVD set that still produces the error. AVS Video Converter can convert the titles without errors. MakeMkv, however, produces an error and aborts making the mkv file for the problem titles. I ran MakeMkv with debugging on and have the log. Perhaps this information can help narrow down the problem.
MakeMKV_log.txt
(745.43 KiB) Downloaded 2663 times
Post by mike admin »
PeacePipe wrote:First failure of any kind I've ever experienced. (Using MakeMKV for 2-3 years.)
Best regards
Please enable debug log and see if anything shows up. Also, make sure you're using the latest version - 1.8.0
T-bonebill
Post by T-bonebill »
ANy update on this? New user to Makemkv. go this error on A Chinese Ghost Story
I enabled debug and have attached the log here:
MakeMKV_log.txt
(2.2 KiB) Downloaded 1458 times
It does not look like much information is in there, the copy starts and then stops with a 1 failed message.
Thanks for a great program. these only DVDs so far that will not work with the program.
wrldtvlr
Post by wrldtvlr »
I'm having the same problem with the I'm Alan Partridge DVD. Track 3 (Title 2) gets all the title, then fails. Tried with multiple optical drives and multiple destinations, with and without AnyDVD. Log entries are:
Saving 1 titles into directory Z:/MakeMKV
DEBUG: Code 7 at PT-QVWpr6F12!+sOW+:213135964
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 4294880446 at %3VSbJFKJLZK[g`ZAr$M:213143209
DEBUG: Code 0 at %3VSbJFKJLZK[g`ZAr$M:29404119
DEBUG: Code 0 at a\;2X|KY0-z5BQ^r{QzKS:213136608
DEBUG: Code 0 at *~hnCI|G[w/I^^d}:29395908
DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:213132698
DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:213132146
DEBUG: Code 0 at %\#Rf#g+*H<yf9zBe:29393769
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 2 to file Z:/MakeMKV/title_t02.mkv
0 titles saved, 1 failed
dododge
Post by dododge »
FWIW I Just ran into trouble with the same DVD as the first post ("A Chinese Ghost Story 2" distributed by Mega Star).
What's different now is that that after showing a big pile of warnings and attempts to work around it, it didn't fail, but instead produced an mkv file that has lots of playback issues, showing up as essentially 20+ hours of a grey screen.
makemkv (and
dd
) can back up the disc to an ISO file without any trouble, and VLC seems to be able to play the movie from the ISO, but if I open the ISO with makemkv and try to save the tracks it results in the same warnings and bad output files.
It's almost certainly something to do with the way the disc was authored, because the DVD for "A Chinese Ghost Story" (part 1) from the same company does exactly the same thing.
FWIW opening the disc produces these debug messages:
001003:0020 DEBUG: Code 0 at }jexA76La`JjTu9fehtZ;%:29393631
SDF v098: HL-DT-ST_BD-RE_BP60NB10_1.00_211711211720_SIK08O42A0119
Launching /app/bin/mmgplsrv
003028:0000 Title #1 was added (10 cell(s), 1:38:50)
DEBUG: Code 33554691 at |Kd?-JXa9OU%g"+,:121265292
003038:0000 Cells 2-11 were removed from title end
003026:0000 Title #2 declared length is 0:00:00 while its real length is 0:00:00 - assuming fake title
Title skip vts=2 pgcn=1
DEBUG: Code 33554947 at |Kd?-JXa9OU%g"+,:121265292
003026:0000 Title #3 declared length is 0:00:00 while its real length is 0:00:00 - assuming fake title
Title skip vts=2 pgcn=2
DEBUG: Code 33555203 at |Kd?-JXa9OU%g"+,:121265292
003038:0000 Cells 2-4 were removed from title end
003026:0000 Title #4 declared length is 0:00:00 while its real length is 0:00:00 - assuming fake title
Title skip vts=2 pgcn=3
DEBUG: Code 33555459 at |Kd?-JXa9OU%g"+,:121265292
003038:0000 Cells 2-8 were removed from title end
003026:0000 Title #5 declared length is 0:00:00 while its real length is 0:00:00 - assuming fake title
Title skip vts=2 pgcn=4
DEBUG: Code 33555715 at |Kd?-JXa9OU%g"+,:121265292
003038:0000 Cells 2-10 were removed from title end
003026:0000 Title #6 declared length is 0:00:00 while its real length is 0:00:00 - assuming fake title
Title skip vts=2 pgcn=5
DEBUG: Code 33555971 at |Kd?-JXa9OU%g"+,:121265292
003038:0000 Cells 2-6 were removed from title end
003026:0000 Title #7 declared length is 0:00:00 while its real length is 0:00:00 - assuming fake title
Title skip vts=2 pgcn=6
003028:0000 Title #8 was added (1 cell(s), 0:02:38)
003028:0000 Title #9 was added (1 cell(s), 0:04:08)
followed by around 100 messages of this sort:
004004:0000 The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 4096, attempting to work around
Saving a small 100M track to mkv produces 8000+ more corrupt VOB warnings, and then "1 titles saved.", but the file it saved plays back as 20+ hours of a black screen.
dododge
Post by dododge »
Just tried The H.K. Triad from Mega Star and got the same sort of problems. An ISO can be backed-up and plays okay in VLC, but trying to extract the video tracks with makemkv mostly results in super-long videos of nothing.
